Identify Task issues
11903
25
04-13-2010 08:40 AM
AngelGonzalez
I am using the ESRI sample for Identify and got a problem. I have a sublayer list with about 13 layers. Only the first 4 are set to be visible when the silverlight app is first run. The identify Task works fine with these first 4 layers. When I click on the checkbox to make another layer visible and use the Identify tool the fifth layer does not appear on the identify tool. Yet when I go back and update the mxd to make the fifth layer visible and reboot my ArcGIS server (the refreshing of a service to pickup and any changes made to the mxd is not being pickup by Silverlight app, only a reboot will do this , bug??) the identify tool picks up the the fifth layer.
Does the Identify task works with sublayer list? Do I need to refresh something?
I am using SL3 with ESRI 1.2 SL API
Angel
JenniferNery
For your first question:
identifyParams.LayerOption = LayerOption.visible;
For your second question:
identifyParams.LayerIds.AddRange(new int[] {1,5,17,18});
MarkCederholm
The only method I've found is to keep track of which layers are visible at a given "scale" (ESRI deprecates that term nowadays) and provide those IDs with the "all" option each time I make an identify request.  It takes a bit of logic to sort through the layers, I'm afraid.
Check out the table of contents at the silverlight code gallery for an example of maintaining visibility info.  You can use REST calls to grab the min and max scales for each layer, but that's pretty chatty.  To keep things simpler, what I ended up doing was create a WCF service to get all the layer info with one SOAP call:  if you add a web reference to the map service in your ASP project it automatically builds the methods and data structures for you.
SanjayRajput
Hello Mark Cederholm/Others
   I am looking for the code snippet to find the current visible layers of a given dynamicmapservice.
During application startup, dynamicmapservice loads all visible layers on the map(defined in the mxd). But after a while users can TURNON/TURNOFF layers. And when I do the QUERYTASK, I should be able to QUERY only current visible layers.
Sanjay
MarkCederholm
Again, I highly recommend the Silverlight Table of Contents code example in the code gallery.  Here's a link to it:
http://www.arcgis.com/home/item.html?id=acad4f3fb7d04854ab8dbe3fc5f79fc5
MatthewPilgrim
I have a similar issue to the first poster (my last layer fails) however my layer is on by default and I get this exception from ESRI.ArcGIS.Client.Tasks.TaskFailedEventArgs:
Error {System.Net.WebException: The remote server returned an error: NotFound. ---> System.Net.WebException: The remote server returned an error: NotFound.
   at System.Net.Browser.BrowserHttpWebRequest.InternalEndGetResponse(IAsyncResult asyncResult)
   at System.Net.Browser.BrowserHttpWebRequest.<>c__DisplayClass5.<EndGetResponse>b__4(Object sendState)
   at System.Net.Browser.AsyncHelper.<>c__DisplayClass2.<BeginOnUI>b__0(Object sendState)
   --- End of inner exception stack trace ---
   at System.Net.Browser.AsyncHelper.BeginOnUI(SendOrPostCallback beginMethod, Object state)
   at System.Net.Browser.BrowserHttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
   at System.Net.WebClient.GetWebResponse(WebRequest request, IAsyncResult result)
   at System.Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result)} System.Exception {System.Net.WebException}
My service has layer ids 0,2,3,4,5,6 (note no number one - and none of them are group layers).  All work except 6.  I have tried calling the Identify task with and without layer options but I still get the exception.
If I pass in Id "5" the results come back for a layer with the correct name - excellent.
If I pass in Id "1" I don't get an exception, but I also get no results.
If I pass in Id "7" I get the same exception as before.
Any Ideas?
Thanks, Matt
JenniferNery
Subscribe to Failed event and check for exception. Also, you might want to run Fiddler with your application to see more information on which web request failed.
void QueryTask_Failed(object sender, TaskFailedEventArgs e)
 if (e.Error is ServiceException)
  StringBuilder sb = new StringBuilder();
  foreach(string detail in (e.Error as ServiceException).Details)
   sb.Append(string.Format("{0}\n", detail));
  MessageBox.Show(string.Format("Error: {0}", sb.ToString()));
If the layer ID is up to 6, ID=7 is expected to fail, right?
Try to see if putting the same parameters from the web browser will result to the same error.
MatthewPilgrim
Jennifer thanks for your response.
Yes I expect 7 to fail.
The exception is of type "System.Net.WebException" so I don't think your code snippet helps.
I'm looking into fiddler and calling the service, not something I've done before.
Matt
JenniferNery
You can place a breakpoint in the Failed event handler, if it does go there.
Post #14 in this thread might guide you in finding what you need to look for in Fiddler: http://forums.arcgis.com/threads/14730-Area-And-Perimeter
MatthewPilgrim
the exception I posted orginally was fromn the failed event handler and is as much information as I can see at that point.
From fiddler I can see the server response is:
Server Error - Index was outside the bounds of the array
This is the service:
This is me calling it (note the watch value is 6):
I'm trying to callit direct at the moment.
Matt
MatthewPilgrim
from fiddler:
tolerance 2
returnGeometry true
mapExtent 3219613.08846863,1726402.76275839,3226995.61041765,1732899.38207353
layers top:6
imageDisplay 1175,825,96
geometryType esriGeometryPolygon
geometry {"spatialReference":{"wkid":2232},"rings":[[[3219613.08846863,1732899.38207353],[3226995.61041765,1732899.38207353],[3226995.61041765,1726402.76275839],[3219613.08846863,1726402.76275839],[3219613.08846863,1732899.38207353]]]}
f json
One thing I notice is that it says "top:6", I didn't specify Top.
I have now tested the webservice direct with All:6 and Top:6 and in both cases get:
Server Error - Index was outside the bounds of the array.
Code: 500
Is it really using Ids and not Index or is it doing a bit of both????
Matt
