How we can customize FeatureDataForm source code
1000
05-30-2012 06:03 AM
shariqueabdul
Hi All
i have downloaded ESRI Silverlight toolkit source code from codeplex.com and i need to change/extend some functionality of FeatureDataForm such as "add cancel button beside Apply to close the window or header/footer etc . so how can i do this .i tried but could not change ... please help me , i stuck here ...
regards
Shar
JenniferNery
If you are just adding a button, I think you can get by with just updating style: http://blogs.esri.com/esri/arcgis/2010/05/28/localizing-arcgis-controls/ and implementing its click event. But if you feel you would need to modify code/behavior, in the Toolkit source code, look for "CommitButton" in FeatureDataForm.Theme.xaml, this is the "Apply" button.
shariqueabdul
Hi jennifednery
thanks for prompt reply ....
i already found apply button(from resource.resx) (whose name is commitbutton in featuredataform.theme.xml) and i also added "Cancel button" on upper right corner but when i handle its click event its give following error ...
"Line: 56
Error: Unhandled Error in Silverlight Application
Code: 2531
Category: ParserError
Message: Failed to assign to property 'System.Windows.Controls.Primitives.ButtonBase.Click'.
File:
Line: 108
Position: 160 "
i just added button in xaml and write some code to popup message box on button1_Click event .
and how can i change the Dll name from ESRI.ArcGIS.Client.Toolkit
plz help
DominiqueBroux
Esri Frequent Contributor
You can't directly add an event handler to default template of a templated control.
To hook up to events of anything in the template you have either to create a template part or to create a command to bind to.
That being said, as Jennifer mentionned, you likely don't need to modify the code of the control. Styling the control should do the trick.
