how to Zoom to point?
13148
9
09-27-2010 07:01 AM
StefhanCampos
Hi, i am trying zoom to a point in map, but doesn't work, i know cannot zoom to a point, and need make a new extent but how i can do that with silvelright api?
JMcNeil
Like a bookmark?
Check out http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#NavigationActions
 <Button Style="{StaticResource MenuItem}"
                            Content="Zoom To" >
                        <i:Interaction.Triggers>
                            <i:EventTrigger EventName="Click">
                                <esri:ZoomToAction
                                    TargetName="MyMap">
                                    <esri:ZoomToAction.Geometry>
                                        <esri:Envelope XMin="-110" YMin="40" XMax="-100" YMax="50" />
                                    </esri:ZoomToAction.Geometry>
                                </esri:ZoomToAction>
                            </i:EventTrigger>
                        </i:Interaction.Triggers>
                    </Button>
Charles__Jamie_Phillips
Here is a code example on how to zoom to a point.  Why does it not work for you?
MapPoint myPoint = new MapPoint(x, y, spatialRef);
MyMap.ZoomTo(myPoint);
or you can do it like in the interactive sdk example for the "Find an Address" example.
StefhanCampos
I want zoom a point(like image bottom), a point dont have start and end, when i zoom geometry, nothing happens, because dont have start and end, i suppose
JenniferNery
You can use the following code, where mapPoint is the point geometry you want to zoom to.
MyMap.ZoomToResolution(MyMap.Resolution / MyMap.ZoomFactor, mapPoint);
dotMorten_esri
Esri Notable Contributor
The above code only zoom "around" that point (meaning that's the point that will stay at the same place on the screen, similar to a double-click zoom where the point you clicked stays at the same position).
I'm guessing you want to the point centered on the screen?
As you found out, you cannot zoom to a point, since a point has an infinitely small extent. The map simply doesn't know how far in you want to zoom. If the point represents an address, you probably want to zoom further in than if the point represents a city.
You can zoom to a point by constructing an extent around the point. ie.
Envelope env = new Envelope(p.X - 500, p.Y - 500, p.X + 500, p.Y + 500);
MyMap.ZoomTo(env);
In this example if the map units are meters, it would zoom to a 1kmx1km box centered on the point 'p'. Based on your map units and the scale you want to zoom to, you probably want to use a different number.
Alternatively you can just pan to the point: Ie: MyMap.PanTo(p);
ducksunlimited
MyMap.ZoomTo(env);
I used the points from a FINDTASk - but couldn't make it work. here are the codes, Any suggestions would be appreciated!
FindResult findResult = (FindResult)FindDetailsDataGrid.SelectedItem;
Graphic graphic = findResult.Feature;
ESRI.ArcGIS.Client.Geometry.Envelope selectedFeatureExtent = new ESRI.ArcGIS.Client.Geometry.Envelope(graphic.Geometry.Extent.XMin, graphic.Geometry.Extent.YMin, graphic.Geometry.Extent.XMax, graphic.Geometry.Extent.YMax);
MyMap.ZoomTo(selectedFeatureExtent);
ducksunlimited
OK, I made it work by adding and subtracting a number for X and Ys
thanks for the codes
DominiqueBroux
Esri Frequent Contributor
You might also be interested by a centerAndZoom function:
private void centerAndZoom(ESRI.ArcGIS.Client.Map map, ESRI.ArcGIS.Client.Geometry.MapPoint mapPoint, double resolution)
double ratio = 1.0;
if (map.Resolution != 0.0)
ratio = resolution / map.Resolution;
if (ratio == 1.0)
map.PanTo(mapPoint);
else
ESRI.ArcGIS.Client.Geometry.MapPoint mapCenter = map.Extent.GetCenter();
double X = (mapPoint.X - ratio * mapCenter.X) / (1 - ratio);
double Y = (mapPoint.Y - ratio * mapCenter.Y) / (1 - ratio);
map.ZoomToResolution(resolution, new ESRI.ArcGIS.Client.Geometry.MapPoint(X, Y));
You can use it to center on a point and zoom to a given resolution.
For example
centerAndZoom(MyMap, pt, MyMap.MinimumResolution * 4);
ChuckDavidson
double ratio = 1.0;
if (ratio == 1.0)
else
For example
Center and Zoom needs to be modified for couple of reasons
- need to compensate for center when current resolution is already less than minimum resolution
- need to compensate for center when current extent envelope does not contain the input point
            if (Math.Round(map.Resolution,5) <= Math.Round(map.MinimumResolution,5))
            else
