How to stop identify from bringing back aliases
3299
05-09-2013 01:55 PM
DonFreeman
When a map service is published with field aliases, an identify against that service also brings back the alias as the attribute key. If the alias includes spaces it cannot be used in a Binding. (or can it?) So my problem is how to configure the identify task to bring back the actual field names rather than the field aliases?
Thanks
AlaaBakry
Hello is there any resolution for this issue!, i want names instead of aliases.
the worst part is: I changed all the aliases in the MXD to be the same as field names, and yet I'm getting old aliases!. it's weird.
I'm using layers joined with other tables, and actually the field aliases are not unique.
ArcGIS Server 10.3
Please help!
AlaaBakry
Freeman, have you been able to get around this?
