How to stop a feature layer edit save
1446
09-27-2011 03:30 PM
DonFreeman
I am trying to validate an email address before proceeding with edits on a SDE feature layer. The edits are taking place via a FeatureDataForm. I have the following code.
  private void FeatureLayer_BeginSaveEdits(object sender, ESRI.ArcGIS.Client.Tasks.BeginEditEventArgs e)
   Graphic SelectedGraphic = MyFeatureDataForm.GraphicSource;
   IDictionary<string, object> attributes = SelectedGraphic.Attributes;
   var msgToAM = attributes["AMEmail"] as string;
   var msgToPM = attributes["PMEmail"] as string;
   var msgToSat = attributes["WkEndEmail"] as string;
   var msgLocation = attributes["Location"] as string;
   if (SelectedFeatureLayer.ID == "AllAvailableFeatureLayer" )
    if ((msgToAM.Length == 0 || msgToAM == "Type email here") & (msgToPM.Length == 0 || msgToPM == "Type email here"))
     MessageBox.Show("Please provide a valid email address.");
     return ;
This works but the save continues. How can I stop the save after the messagebox is displayed?
Thanks.
GarimaVyas
Don,
You should set the AutoSave to False and listen to EditEnded instead of BeginSaveEdits. Check out this forum discussion as well.
DonFreeman
Don,
Thanks G. -
Sorry for my lack of experience but I don't seem to find EditEnded. The reference to it here produces an error.
     <esri:FeatureLayer ID="AllAvailableFeatureLayer"
      Url="http://gismaps.pagnet.org/ArcGIS/rest/services/BikeCountLocations/FeatureServer/0"
      Renderer="{StaticResource AllRenderer}"
      MouseLeftButtonUp="FeatureLayer_MouseLeftButtonUp"
      SelectionColor="Yellow"
      OutFields="Location,AMVolunteer,AMPhone,AMEmail,PMVolunteer,PMPhone,PMEmail"
      DisableClientCaching="True"
      Where="AMVolunteer = 'Available' and PMVolunteer = 'Available'"
      AutoSave="False"
      BeginSaveEdits="FeatureLayer_BeginSaveEdits"
      EndSaveEdits="FeatureLayer_EndSaveEdits"
      EditEnded="featureLayer_EditEnded"    >
DonFreeman
Don,
Got it! Thanks. It took me a while to find EditEnded as it is tied to the dataform not the feature layer. But it is very helpful. Thanks
dotMorten_esri
Esri Notable Contributor
Just set e.Cancel = true;
