How to show OBJECTID column in feature data grid
1278
05-17-2012 08:41 AM
MattMiley
How do I show a OBJECTID column in feature data grid.
My attempted below..
<esriToolkit:FeatureDataGrid Grid.Row="2" x:Name="MyDataGrid" SelectionChanged="Feature_DataGrid_SelectionChange"        Map="{Binding ElementName=MyMap}"        GraphicsLayer="{Binding Layers.[Job Points], ElementName=MyMap}" >              <esriToolkit:FeatureDataGrid.Columns>                     <sdk:DataGridTextColumn Width="100" Binding="{Binding  Attributes[OBJECTID]}" Header="Job ID"/>                 </esriToolkit:FeatureDataGrid.Columns>             </esriToolkit:FeatureDataGrid>
ChristopherHill
The ItemsSource of the FeatureDataGrid in silverlight does not contain graphics. It contains a PageViewCollection of a reflection class that is built based on the number unique attribute names inside all of your Graphic.Attributes.Keys. Your binding should not include Attributes.
JenniferNery
Have you seen this SDK sample? http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureDataGrid
Few things to note in this sample, FeatureDataGrid Map and GraphicsLayer property (see element binding) and FeatureLayer.OutFields. In this sample, it is "*" which means show all fields. Otherwise, if you only want ObjectID to show, change FeatureLayer.OutFields="ObjectID".
ChristopherHill
