How to set selection color with custom renderer
1418
5
02-15-2011 05:45 AM
DonFreeman
My featureLayer is drawn with a custom renderer.
 <Grid.Resources>
   <esri:SimpleRenderer x:Key="AMRenderer">
    <esri:SimpleRenderer.Symbol>
     <esriSymbols:SimpleMarkerSymbol x:Name="AllMarkerSymbol" Color="Green" Style="Circle" Size="8" />
    </esri:SimpleRenderer.Symbol>
   </esri:SimpleRenderer>        </Grid.Resources>
     <esri:FeatureLayer ID="AMAvailableLayer"
      Url="http://gismaps.pagnet.org/ArcGIS/rest/services/testprojectALLBikeCounts/FeatureServer/0"
      MouseLeftButtonUp="FeatureLayer_MouseLeftButtonUp"
      SelectionColor="Yellow"
      OutFields="Location,VolunteerAM,PhoneAM,EmailAM,SpanishAM"
      Where="VolunteerAM = 'Available' and VolunteerPM != 'Available'"
      Renderer="{StaticResource AMRenderer}"
      DisableClientCaching="True"
      AutoSave="True"
      EndSaveEdits="FeatureLayer_EndSaveEdits">
      <esri:FeatureLayer.MapTip>
       <Border CornerRadius="10" BorderBrush="SaddleBrown" BorderThickness="3" Margin="0,0,15,15" Background="LightGray">
        <StackPanel Margin="7">
         <StackPanel Orientation="Horizontal">
          <TextBlock Text="Location: " Foreground="Black" FontWeight="Bold"/>
          <TextBlock Text="{Binding [Location]}" Foreground="Black" />
         </StackPanel>
        </StackPanel>
       </Border>
      </esri:FeatureLayer.MapTip>
     </esri:FeatureLayer>
Note that the selection color in the layer is set to Yellow. In operation this places a yellow square around the selected point (very hard to see) but does not change the color of the point itself. How can I change my code so that the symbol for the selected point becomes yellow?
JenniferNery
Instead of using SimpleMarkerSymbol in your SimpleRenderer, you can use symbols that define their template as in this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SelectGraphics. Notice how the template has VisualStates defined for Selected.
DonFreeman
This is a FeatureLayer that I am working with. I was previously advised that I had to use the custom renderer to override the default symbol in the service. This seems to be true as setting a symbol like this:
FeatureSymbol="{StaticResource SelectMarkerSymbol}"
has no effect. The code for the resource is taken directly from the sample you referenced.
DonFreeman
Thanks Jenn. The light came on right after I sent the previous post. It works. 🙂
DonFreeman
Jenn -
Would it also be possible to change the size of the ellipse? Something like
<Storyboard>
           <ColorAnimation Storyboard.TargetName="Element"
            Storyboard.TargetProperty="(Ellipse.Fill).(SolidColorBrush.Color)"
            To="Yellow" Duration="00:00:0.25"/>
           <PointAnimation Storyboard.TargetName="Element" Storyboard.TargetProperty="(Ellipse.Height)" To="15" Duration="00:00:0.25"/>
          </Storyboard>
JenniferNery
Sure, you can apply ScaleTransform to your symbol as shown in this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#CustomSymbols
Look for this "Enlarge gradient marker symbol" in XAML. You can use similar code in your Selected state.
