How to set LayerIds in IdentifyParameters?
3796
07-01-2010 11:17 PM
UlfGrimhardt
Hi
I want to set just one Layer to be identified by the Identify Function. I tried this code:
            ESRI.ArcGIS.Client.Tasks.IdentifyParameters identifyParams = new IdentifyParameters()
                Geometry = clickPoint,
                MapExtent = map.Extent,
                Width = (int)map.ActualWidth,
                Height = (int)map.ActualHeight,
                LayerOption = LayerOption.visible,
                LayerIds = [0]
But it doesnt work, so i would like to know how can i set the LayerIds value?
DominiqueBroux
Esri Frequent Contributor
Use Add or AddRange method of the LayerIds collection:
identifyParams.LayerIds.Add(1);
identifyParams.LayerIds.Add(3);
identifyParams.LayerIds.Add(5);
or
identifyParams.LayerIds.AddRange(new int[] { 1, 3, 5 });
UlfGrimhardt
Doesnt work.
VisualStudio underlines LayerIds with following Error:
Error Invalid initializer member declarator
DominiqueBroux
The methods can't be called in object initializer. Need to be called after.
