How to Select a graphic
1082
12-22-2010 10:54 AM
PLadd
I want to select a graphic that has already been drawn on the map.  I can't seem to piece this together from sample code so I would appreciate some help.
I have a tiled parcel layer.  When a user IDs (selects) a parcel, a graphic is created showing that selected parcel.  The user would then open a Buffer distance window, enter in a distance and hit OK.  The OK button would fire some kind of code-behind to select the graphic created by the selected parcel (and eventuall buffer it - but I'll ask that in another post if needed).
Can somebody throw me some code that will select an existing graphic?  Thanks.
ThaoLe
Can you post the code you currently have?
I think what you can do is to keep a reference to the geometry that you get back from your IdentifyTask. Use that geometry and send it to your buffer.
PLadd
After clicking on a parcel, the two pieces of code below run:
private void MyDrawSurface_DrawComplete(object sender, ESRI.ArcGIS.Client.DrawEventArgs args)
            GraphicsLayer selectionGraphicslayer = MyMap.Layers["MySelectionGraphicsLayer"] as GraphicsLayer;
            selectionGraphicslayer.ClearGraphics();
            QueryTask selqueryTask = new QueryTask("http://myserver/arcgis/rest/services/Parcels/MapServer/0");
            selqueryTask.ExecuteCompleted += selQueryTask_ExecuteCompleted;
            selqueryTask.Failed += selQueryTask_Failed;
            // Bind data grid to query results
            Binding resultFeaturesBinding = new Binding("LastResult.Features");
            resultFeaturesBinding.Source = selqueryTask;
            Query query = new ESRI.ArcGIS.Client.Tasks.Query();
            // Specify fields to return from query
            query.OutFields.AddRange(new string[] {"GIS_ID", "StreetNumber", "StreetName", "CurrentOwner"});
            query.Geometry = args.Geometry;
            // Return geometry with result features
            query.ReturnGeometry = true;
            selqueryTask.ExecuteAsync(query);
        private void selQueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
            FeatureSet featureSet = args.FeatureSet;
            if (featureSet == null || featureSet.Features.Count < 1)
                MessageBox.Show("No features returned from query");
                return;
            GraphicsLayer graphicsLayer = MyMap.Layers["MySelectionGraphicsLayer"] as GraphicsLayer;
            if (featureSet != null && featureSet.Features.Count > 0)
                int i = 0;
                myGIS_ID = "";
                foreach (Graphic feature in featureSet.Features)
                    feature.Symbol = selResultsFillSymbol;
                    graphicsLayer.Graphics.Insert(0, feature);
                    if (i == 0)
                        myGIS_ID = featureSet.Features.Attributes["GIS_ID"].ToString();
                    else
                        myGIS_ID = myGIS_ID + "," + featureSet.Features.Attributes["GIS_ID"].ToString();
                    i = i + 1;
                LoadAssessor("Map"); //load Property Grid from parcel(s) clicked on
           // MyDrawSurface.IsEnabled = false; //removed so user can continuously use tool - add to ID enable tool
PLadd
This seems to be doing the trick:
            GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            Graphic g = new ESRI.ArcGIS.Client.Graphic();
            if (graphicsLayer.Graphics.Count > 0)
                IList<Graphic> graphicsList = graphicsLayer.Graphics;
                foreach (Graphic graphic in graphicsList)
                    g.Geometry = graphic.Geometry;
            else
                MessageBox.Show("Nothing selected");
                return;
Then I can buffer the GraphicsLayer.  It's got other issues that need to be worked out but this will get me up and running.
