how to retrieve a graphic that contains a drawing point
5306
15
12-17-2010 10:22 AM
ThaoNguyen
My scenario:
- I have a drawing "point" icon for my map.  When I click on a region in US, I want to highlight that region.  I can get the highlight done.  When clicking on a region, I don't want to run the query task again to get the region that contains the point.  So, my design is I go thru the existing graphic list and find the region that "intersects" with that point, then do the highlight.
Something like this:
if (graphic.Geometry.Extent.Intersects(e.Geometry.Extent))
      graphic.Select();
e is DrawEventArgs.  graphic is from graphic layer on the map.
However, I got a problem that sometimes 2 regions contain that point and the result is both of them are selected.  Please see the attached image, my clicking point is at the crossed symbol x. When I click at that point, both regions A and B are selected while I only want region B is selected.
Is there a way to fix this?  Looks like to me graphic geometry is a rectangle and that causes the point to be inside both regions in the image?
I appreciate your help!
ThaoNguyen
My scenario:
      graphic.Select();
Attach the image.
JenniferNery
You can try this SDK sample http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SpatialQuery. It uses QueryTask based on the geometry (i.e. MapPoint if DrawMode is Point). You can modify this sample, you will not need a Draw object. You can obtain MapPoint through any of the mouse events.
System.Windows.Point screenPoint = args.GetPosition(MyMap);
ESRI.ArcGIS.Client.Geometry.MapPoint mapPoint = MyMap.ScreenToMap(screenPoint);
ThaoNguyen
Jennifer,
Like I said, I didn't want to run QueryTask again.  I had looked at that spatial query before posting this question.  I just want to use the exisitng graphics that I already query earlier and look for the one that contains the point.  Looks like there is no way to get the right graphic WITHOUT running QueryTask?
JenniferNery
How about using FindGraphicsInHostCoordinates? You can look at the MouseClick event handler in this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#InfoWindowSimple
AliMirzabeigi
You can do the following in the MouseClick event of your Map control to get the graphics that intersect your MapPoint.
Assumptions in the code snippet:
- MyMap: The Map control in your application
- MyFeatureLayer: The FeatureLayer in your map you are intersecting the map point
- MyGraphicsLayer: The layer to show the intersecting result(s)
FeatureLayer featureLayer = MyMap.Layers["MyFeatureLayer"] asFeatureLayer;
System.Windows.Point screenPnt = MyMap.MapToScreen(e.MapPoint);
GeneralTransform generalTransform = MyMap.TransformToVisual(Application.Current.RootVisual);
System.Windows.Point transformScreenPnt = generalTransform.Transform(screenPnt);
IEnumerable<Graphic> results = featureLayer.FindGraphicsInHostCoordinates(transformScreenPnt);
GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] asGraphicsLayer;
foreach (Graphic graphic in results)
Graphic g = newGraphic() { Geometry = graphic.Geometry };
graphicsLayer.Graphics.Add(g);
ThaoNguyen
Thanks Jennifer and Ali! Looks like that can resolve my problem, but I cannot test it because I cannot find the property RootVisual from Application.Current.  I tried Application.Current.MainWindow but that is null.
JenniferNery
If you are using WPF:
GeneralTransform generalTransform = MyMap.TransformToVisual(Application.Current.MainWindow);
IEnumerable<Graphic> selected =
                parcelGraphicsLayer.FindGraphicsInHostCoordinates(transformScreenPnt);
ThaoNguyen
I used MainWindow, but it always returned me null.
ThaoNguyen
I found out why it is always null for my case.
Another question. My xaml has something like this:
<UserControl>
<UserControl.Resources/>
<Grid>my map is in here</Grid>
</UserControl>
Is that true that the MainWindow would be the Grid element in my xaml?
