How to obtain feature ID
7174
27
11-16-2010 10:18 AM
DonFreeman
Is there a sample around that shows how to obtain the feature ID (place it into a variable) when the user clicks on a point feature?
Silverlight 4
DonFreeman
You can do this by listening to the FeatureLayer_MouseLeftButtonUp event handler. Use the following code snippet to get the attribute collection of the Graphic object that has been clicked by the user:
IDictionary<string, object> attributes = e.Graphic.Attributes;
TaDa!! It works. Thanks so much to both of you.
  private void FeatureLayer_MouseLeftButtonUp(object sender, GraphicMouseButtonEventArgs args)
   FeatureLayer featureLayer = sender as FeatureLayer;
   for (int i = 0; i < featureLayer.SelectionCount; i++)
    featureLayer.SelectedGraphics.ToList().UnSelect();
   args.Graphic.Select();
   IDictionary<string, object> attributes = args.Graphic.Attributes;
   MessageBox.Show("This FID = " + attributes["FID"]) ;
Now, is there a way I can change the symbol for the selected and unselected points in the FeatureLayer?
AliMirzabeigi
Please take a look a the following SDK sample to get the whole idea:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SelectGraphics
You would need to set the FeatureSymbol property of your FeatureLayer to your custom symbol.
DonFreeman
The sample uses graphics, I am using a FeatureLayer. Meanwhile I found this information.
http://help.arcgis.com/en/webapi/silverlight/help/creating_featurelayer.htm
Using the info therein I coded my map to match their sample like this.
<Grid.Resources>
    <esriSymbols:SimpleMarkerSymbol x:Name="MyMarkerSymbol" Color="Red" Style="Diamond" Size="10" />
   </Grid.Resources>
   <esri:Map x:Name="MyMap" Grid.RowSpan="2" >
    <esri:Map.Layers>
     <esri:ArcGISDynamicMapServiceLayer ID="SchoolSearch3"
      Url="http://198.182.104.173/ArcGIS/rest/services/SchoolSearch3/MapServer"       VisibleLayers="0,1"/>
     <esri:FeatureLayer ID="MyFeatureLayer"
      Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0"
      MouseLeftButtonUp="FeatureLayer_MouseLeftButtonUp"
      DisableClientCaching="True"
      Mode="OnDemand"
      OutFields="*"
      SelectionColor="Yellow"
      FeatureSymbol="{StaticResource MyMarkerSymbol}" >
     </esri:FeatureLayer>
    </esri:Map.Layers>
   </esri:Map>
which seems to work as expected except that I don't get the yellow selected color. However, when I substitute MY url in place of the sample, (Url="http://198.182.104.173/ArcGIS/rest/services/Intersection_Test/MapServer/0") it does not work. So the conclusion is that I must need to do something to the service to make this work? Correct? and if so what?
AliMirzabeigi
If you can't see your layer on the map you may be using an ArcGIS Server service over a scheme different than the host application, please make sure you have the clientaccesspolicy.xml on your services Web server. More info here: http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2009/08/31/Using-services-across-schemes.aspx
If the above is not the problem and you can see your layer then if your layer has a Renderer defined in its service you can replace it with your own Renderer and use FeatureLayer's Renderer property to override the Renderer used in your FeatureLayer, i.e.
<esri:FeatureLayer ID="MyFeatureLayer" Renderer="{StaticResource PointSymbol}" ... />
Where:
<Grid.Resources>
 <esri:MarkerSymbol x:Key="SelectMarkerSymbol" >
  <esri:MarkerSymbol.ControlTemplate>
   <ControlTemplate>
    <Ellipse x:Name="Element" Width="15" Height="15" StrokeThickness="10"
       Stroke="Green" >
     <VisualStateManager.VisualStateGroups>
      <VisualStateGroup x:Name="SelectionStates">
       <VisualState x:Name="Unselected" />
       <VisualState x:Name="Selected">
        <Storyboard>
         <ColorAnimation Storyboard.TargetName="Element"
          Storyboard.TargetProperty="(Ellipse.Stroke).(SolidColorBrush.Color)"
          To="Cyan" Duration="00:00:0.25"/>
        </Storyboard>
       </VisualState>
      </VisualStateGroup>
     </VisualStateManager.VisualStateGroups>
    </Ellipse>
   </ControlTemplate>
  </esri:MarkerSymbol.ControlTemplate>
 </esri:MarkerSymbol>
 <esri:SimpleRenderer x:Key="PointSymbol" Symbol="{StaticResource SelectMarkerSymbol}" />
</Grid.Resources>
DonFreeman
Its not a problem with cross domain and yes I can see the layer in my map, I just can't get it to show with a different symbol. How would my service have been defined with a built in Renderer? I can modify the service if necessary to avoid additional coding to deal with it.
JenniferNery
You can look at this help doc http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#/Authoring_fea...
There is a section on defining symbology.
DonFreeman
Do I infer correctly that to make use of FeatureSymbols the FeatureLayer must be based on a FeatureService and not a MapService?
JenniferNery
FeatureSymbol is used when the FeatureLayer (regardless if it comes from Feature Service or Map Service) does not already have a Renderer.
You can define the Renderer in the service itself or in the application. The help doc in my previous post describes how it's done on the service.
http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.GraphicsLa...
Here's a sample how Renderer can be defined in your application: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureLayerRendering
