How to make Export() is work with ArcGIS API for Silverlight!
4135
14
12-08-2011 06:19 PM
AnhTruong
Hello ESRI expertise!
I like to export the data query from your ArcGIS API for Silverlight example to Excel.
You can see the data query at:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#QueryWithoutMap
to Excel file. In reality, I can export the data from silverlight datagrid using Export() function that you can refer to http://www.codeproject.com/KB/silverlight/SilverlightDataGridExport.aspx?msg=3297287
Please help to figure out how to export it in ArcGIS API for Silverlight??? Thanks.
DominiqueBroux
Esri Frequent Contributor
AnhTruong
Thank for showing me the example to export ARCGIS query data with Map to Excel. In my case, I need to export ArcGIS query data without map from ArcGIS API for Silverlight that I learn from ArcGIS Resource Center. I am newbie, so I am not confident to make any change from your test code with Map query. Any further help are much appreciated. Thanks.
Darina gave a solution in these threads:
- http://forums.arcgis.com/threads/245...d-Excel-Export
- http://forums.arcgis.com/threads/13460-Export-to-Excel...
AnhTruong
Anyone know to export the QueryWithoutMap datagrid to excel file via Export button? I have read the Darina Tchountcheva FeatureDataGrid Excel Export with map, but I could not figure out how to modify without map in code. I am re-attached link http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#QueryWithoutMap for visualize what I need on data to export. I look forward any helps to solve my issue soon.
DominiqueBroux
I tweaked the Darina's code to get it working with the sample you pointed out.
Attached are the sources and an example of output csv file.
AnhTruong
Hello Dominique,
I really appreciate your time and your ArcGIS expertise to help me out on this issue. Thanks again.
MaciejGolebiewski
Hello,
I've got an error when implementing the code. 😞
It crashes when I click "Save" in "Save as... dialog", problem lies in this part:
private static string GetValue(FrameworkElement frameworkElement)
            return frameworkElement is TextBlock ? (frameworkElement as TextBlock).Text : frameworkElement.ToString();
The error says: "NullReferenceException was unhandled by user code"
I tried to workaround it this way:
            if (frameworkElement != null)
But then it underlines "GetValue" and says: "'ESRIMinimalMapApplication3.DataGridExtensions.GetValue(System.Windows.FrameworkElement)': not all code paths return a value"
Please help
DominiqueBroux
Please help
Not sure why this method gets called with a null value but to compile it, you need to return a value in case of null value.
Something like:
            else return null;
MaciejGolebiewski
Thanks Dominique - that was fast reply!
It works but not completely correct... 😞
It exports only those rows which are currently visible on the screen (5 of them), depending on where I scroll the datagrid, I want it to export all values, even though they are below the scrollbar.
Another problem is that it exports empty XML.
Any solution?
EDIT:
Same situation concerning the values far to the right of the datagrid 😞
DominiqueBroux
There are discussions about enhancements of this program in these threads:
  - http://forums.arcgis.com/threads/67767-Export-To-Excel-Downloaded-only-records-in-dialog-view
  - http://forums.arcgis.com/threads/63895-Export-To-Excel-Null-Reference-Error
Unfortunately, I am not sure someone published a new version grouping all the fixes.
