How to know if a service has been started
985
05-12-2010 06:01 AM
SebastienPelletier
Hi ,
I want to dynamically add services in my map and before I would like to know if the service was started.
How to know if a service has been started ?
AvronPolakow
Although this doesn't check in advance you can check if the service exists when you call the service.
You need to trap the error but the normal try/catch inline won't capture the error because the error generated is at the application level.
You have to capture the error at the Application Level
1 - Create a global in your XAML Page.cs to hold any error you with to pass eg:
public partial class MainPage : UserControl
   string _strUnhandledException = "";
2 - Where you are dynamically adding your layer preload the variable with any message you might wish to display eg:
         ArcGISTiledMapServiceLayer TiledLayer = new ArcGISTiledMapServiceLayer();
         TiledLayer.ID  = larrValues[0];
         TiledLayer.Url = larrValues[1];
        _strUnhandledException = larrValues[0] + "\n" + larrValues[1];   // «««««««««
        MyMap.Layers.Add(TiledLayer);
3 - In the Application XAML App.xaml.cs go to the event:
     private void Application_UnhandledException
   // Change the code to the following:
   if (!System.Diagnostics.Debugger.IsAttached)
    e.Handled = true;
    if (_strUnhandledException != "") {ReportCustomError(e);}    // « new line
    else
     Deployment.Current.Dispatcher.BeginInvoke(delegate { ReportErrorToDOM(e); });
4 - In the Application XAML App.xaml.cs add this function:
  private void ReportCustomError(ApplicationUnhandledExceptionEventArgs e)
   try
    string errorMsg = e.ExceptionObject.Message + e.ExceptionObject.StackTrace;
    errorMsg          = errorMsg.Replace('"', '\'').Replace("\r\n", @"\n");
    errorMsg  = "Application Unhandled Exception:"
                   + "\n***************************"
                   + "\n" + e.ToString()
                   + "\n" + _strUnhandledException
                   + "\n\n" + errorMsg;
     MessageBox.Show(errorMsg);
     return;
   catch (Exception)
