How to I apply a where clause and envlope to filter features on an ArcGISDynamic Laye
612
04-11-2011 03:02 PM
MuralidharMoka
if we have a feature clause (say f) and say I have an extents and  I create an envelope out of extents say (env)
Then I can do some thing like this
f.Geometry=env
f.where=SomwwhereClause
f.Update()
and the above code filter me all feature within the extents , which meets the filter criteria's
But Say I have an ArcGISDynamicServiceLayer say (fDynamic)
now How I can I do the same,
fDynamic.Where //not possible as where prop is absent
fDynamic.Geometry//not possilbe as Geometry prop is absent
How to achive this.
Muralidhar Moka
MuralidharMoka
If My question was confusing.
To make it very clear.
I have an ArcGISDynamic Layer and It has a featureLayer in it.
How do I work with that feature Layer. Say I want to apply some where clause
or I want to apply envelope on its geometry and filter features in it and display it.
Why I am asking is, I have a task where I have a ArcGISDyanamicServiceLayer which has
100 feature layers in it based on county number and every time, I will have to work on only one feature layer based on the county and also I will need to work on only some features in it filtered by some where clause.
Muralidhar Moka
DominiqueBroux
Esri Frequent Contributor
If your map service is not cached, you can filter with where clauses by using the 'LayerDefinitions'.
Here is the documentation :
http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.ArcGISDyna...
There is no way to filter by using a geometry though. The filtering is automatically done by the ArcGISDynamicMapSerrviceLayer by using the current extent.
