How to get UserControls to talk to each other.
594
07-24-2012 02:02 PM
DorothyMortenson
My codebehind is crazy long and I'd like to "modularize" it a bit.
In my web app, there are two ways to do a search: a) type in a number in a box, or b) draw a rectangle on the map.
Once the selection is done, the rest of the work is pretty much the same - get the attributes and put it into a grid.
I would like to have two user controls, one for a and one for b.  Once the query is done, I'd like to send the "ExecuteCompleted" to a single file (results.cs), where it does a bunch of stuff with the results.
I've made a UserControl of a panel where the user can type in the number in a box, then click a button.
After the button is clicked, a sql string is made and passed to do a query. I could put the ExecuteCompleted in the same file, but I don't really want to. I'd rather have it seperate.  However, I don't know how to get the user control to talk to the results.
Search.xaml - User Control that has a panel with the text box and button.
Search.cs - uses the text box to create a sql statement, passes the sql statement to a query.
Results.cs - has the ExecuteCompleted stuff.
Don't know how to make Search.cs talk to Results.cs
Any ideas?
Here's the code.
Search.cs:
private void CertButton_Click(object sender, RoutedEventArgs e)
            if (CertNum.Text != "")
                // ClearGridGraphics(sender, e);
                string query_string = "cert_nbr = " + CertNum.Text;
                search_waterright(query_string);
            else MessageBox.Show("You have not typed in a number. Please enter a valid number.");
 private void search_waterright(string query_string)
            QueryTask pou_queryTask = new QueryTask("http://weaver.wrd.state.or.us/ArcGIS/rest/services/WR/wr_query/MapServer/1");
           // PART I'D LIKE TO CHANGE
            pou_queryTask.ExecuteCompleted += pou_QueryTask_ExecuteCompleted;
            pou_queryTask.Failed += QueryTask_Failed;
            Query pou_query = new ESRI.ArcGIS.Client.Tasks.Query();
            pou_query.OutFields.Add("*");
            pou_query.Where = query_string;
            pou_query.ReturnGeometry = true;
            pou_queryTask.ExecuteAsync(pou_query);
Results.cs:
        public void pou_QueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
            FeatureSet featureSet = args.FeatureSet;
            int i = 0;
            i = featureSet.Features.Count;
            if (featureSet.Features.Count < 1)
                ViewWaterRights.Visibility = Visibility.Visible;
                POU_WRDetailsDataGrid.Visibility = Visibility.Collapsed;
                POU_Message.Visibility = Visibility.Visible;
                tabItemPOU.Header = "Places of Use: (Count: 0)";
                return;
            GraphicsLayer graphicsLayer = MyMap.Layers["POUResultsGraphicsLayer"] as GraphicsLayer;
            if (featureSet != null && featureSet.Features.Count > 0)
                List<pouClass> pouList = new List<pouClass>();
                foreach (Graphic feature in featureSet.Features)
do a bunch of stuff: gather attributes and put in a grid.
DaveTimmins
you can use something like the messenger from MVVM Light to achieve this. It allows for a clean way to communicate without introducing dependency between code.
Alternatively you can just use simple custom events in your user controls.
Cheers,
DorothyMortenson
That all sounds well and good and I'm hoping one day that will make tangable sense to me. I'm a little thick and I still am not quite getting how to do this.
I've been looking at the mvvm and haven't quite got it well enough to implement. So my preference would be to start with the custom event/handler. anyone have an example?
Dorothy
