How to get attribute columns list
2249
6
11-25-2010 04:55 AM
PaulHuppé
For a given map service and layer, is it possible to get the list of attribute columns?  If so, how?
Paul
ChrisSmith
just call your service via rest for the required layer i.e.
http://servername/ArcGIS/rest/services/NameOfYourService/MapServer/0?f=json
(0 = the layer you want to get info on, change this number to the index of the required layer.)
this will then return the layer description in the specified format and you just need to deserialise or parse the json (in this instance) to get the fields; i.e. look for the following...
"fields":[{"name":"FID","type":"esriFieldTypeOID","alias":"FID"}................
regards
chris
PaulHuppé
Hi Chris,
Thanks for the information.  How do you do that from code behind?
Cheers,
Paul
ChrisSmith
try using WebClient
WebClient client = new WebClient();
                client.DownloadStringCompleted += new DownloadStringCompletedEventHandler(this.Client_DownloadStringCompleted);
                string configUrl = string.Format("{0}{1}", this.Url, "?f=json");
                client.DownloadStringAsync(new Uri(configUrl));
then deserialise the json result.
public static T DeserializeJson<T>(string jsonString)
            using (MemoryStream memoryStream = new MemoryStream(Encoding.UTF8.GetBytes(jsonString)))
                try
                    DataContractJsonSerializer serializer = new DataContractJsonSerializer(typeof(T));
                    T returnObject = (T)serializer.ReadObject(memoryStream);
                    return returnObject;
                catch (Exception e)
                    ////Logging.Log.Error("Deserialize json string");
                    return default(T);
you will need to set up a class that defines the DataContract in the returned json, below is an example for the whole service (MapServer part of url without the layer index)....
using System.Runtime.Serialization;
namespace Your.Namespace
    [DataContract]
    public class DocumentInfo
        [DataMember]
        public string Title { get; set; }
        [DataMember]
        public string Author { get; set; }
        [DataMember]
        public string Comments { get; set; }
        [DataMember]
        public string Subject { get; set; }
        [DataMember]
        public string Category { get; set; }
        [DataMember]
        public string Keywords { get; set; }
        [DataMember]
        public string Credits { get; set; }
    [DataContract]
    public class ExtentConfig
        [DataMember]
        public double? xmin { get; set; }.....
[DataContract]
    public class ServiceConfig
        [DataMember]
        public DocumentInfo documentInfo { get; set; }
        [DataMember]
        public string serviceDescription { get; set; }
        [DataMember]
        public string mapName { get; set; }
        [DataMember]
        public string description { get; set; }
        [DataMember]
        public string copyrightText { get; set; }....
to call the desrialiser would be
ServiceConfig deserialisedConfig = Serializer.DeserializeJson<ServiceConfig>(e.Result);
where e.Result is the DownloadStringCompletedEventArgs parameter of your DownloadStringCompletedEventHandler on the WebClient set at the beginning
should be enough for you to work out how to do it, there are other ways of doing it
hope this helps
regards
chris
PaulHuppé
Hi Chris,
Ok, I will give it a try.
thanks,
Paul
PaulHuppé
I have added a reference to the System.Runtime.Serialization.Json namespace, but the DataContractJsonSerializer Class is not present. I am using Silverlight 4 and the .Net 4 framework, so I do not know why it is not there!
DominiqueBroux
Esri Frequent Contributor
The class DataContractJsonSerializer is in System.ServiceModel.Web.
