How to draw a circle inside a polygon feature.
687
05-10-2011 07:01 AM
MuralidharMoka
Hi .
I have a feature layer which contains polygon features. I have to draw / generate a pivot/circle, inside the polygon, when the user clicks inside the polygon.
I have seen the offset example in Utilities section on the ESRI Silverlight samples site (link below)
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Offset
It is exactly like this, but I want to generate a circle instead. The circle need not touch all sides.
Pls let me know if there is an example like this.
(This is bascially for drawing circular fields)
Muralidhar Moka
JenniferNery
Have you looked at this sample? http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#BufferPoint Maybe instead of using Map.MouseClick, you can use FeatureLayer.MouseLeftButtonDown event, this only fires when your mouse touches a graphic in that layer.
