How to display Lat long points on arcgis services map
1207
12-06-2012 01:38 AM
MuhammadWaqar_ul_islam
i have lat long values 6803.0708,2622.6819
i want to display on arcgis sample
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Project
which map spatialReference no  is required to convert these values to display on map
MapPoint inputMapPoint = new MapPoint(x, y, new SpatialReference(----));
regards
Waqar
MelitaKennedy
Esri Notable Contributor
regards
Waqar
It looks like the values are degrees decimal minutes:
68 03.0708
26 22.6819
if the positions are in Pakistan. They'll first need to be converted to decimal degrees. One simple method is to divide the minutes part by 60 and add to the degree part:
68.05118
26.378031666667
The next question is which geographic coordinate system (datum) are these points based upon? WGS84 or a Pakistan GCS? If the latter, try Kalianpur 1962, well-known ID = 4145.
Melita
MelitaKennedy
regards
Waqar
68 03.0708
26 22.6819
68.05118
26.378031666667
Melita
