How to display a subset of x,y - table
1072
10-20-2013 10:03 PM
AnatoliiTerentiev
I am a newby in silverlight API and before that I worked with ArcObjects SDK 2010. Can't anybody
give any reference on how to display a subset of x,y-table with silverliht API 3.1? Thanks in advance!
YueWu1
by Esri Regular Contributor
Hi Anatolii,
This is a good start to check FeatureDataGrid on silverlight sample:
http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#FeatureDataGrid
Also this is the silverlight API about Datagrid
http://resources.arcgis.com/en/help/silverlight-api/apiref/api_start.htm?ESRI.ArcGIS.Client.Toolkit~...
AnatoliiTerentiev
I need to work with mysql -table , wich contains x,y - data about events. I use arcgis 10.1 for server and desktop, visual studio 2012. When working with previous releases I formed shape file and refresh map (I use arcobjects). I know that in arcgis powerful tools to work with objects, but need to use the database SQL-server, ArcSDE   etc. Can I use these tools when working with mysql?
AnatoliiTerentiev
As I understand, it works with the map layer. Do I understand correctly that, in any case, to solve this problem it is necessary to create a layer in code-behind on the basis of x,y - table. There is no service that displays a selection of the table records with the specified symbol ?
  And by the way. How to create a layer from the selection of x,y - table?
AnatoliiTerentiev
Because shape file is locked  when  service is published, it is necessary to use ArcSDE or some of the SQL servers , when it is need to show x,y table with to enable adding records. Is it true?
PS. That is I can't use only mysql for this task?
