how to create a map using arcgis engin.
858
01-03-2011 08:20 PM
MAsiq_raja
hi
  I very new to this, so i don't abc of this, so could any tell me how to create a map and want to show the given address with the push pin. so could any help to find solution for this problem.
Thanks in Advance
AliMirzabeigi
First, you need to to create services in your ArcGIS Server. The following links explain how to publish GIS resources in a server: http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#//00930000005w...
http://help.arcgis.com/en/arcgisserver/10.0/help/arcgis_server_dotnet_help/index.html#//00930000005z...
Next, take a look at the following SDK sample to see how you can find an address of a location on your map (see the tooltip text associated with the marker symbol after you clicked on the map).
