Open your map and zoom to the extent you want when you use the Full extent.
Right click on your data frame (usually called "Layer") and select Properties
Select the Data Frame tab
Under "Extent Used By Full Extent Command" select "Other" and click on "Specify Extent..."
Select "Current Visible Extent" and click on OK twice
You've now set your maximum extent.
