How to Bind to geometry in listbox
1022
08-19-2012 05:37 PM
MattMiley
Is is possible to bind to a graphic's geometry in the xaml?
     <TextBlock  Text="Job # " FontSize="44" />                             <TextBlock  Text="{Binding Attributes[OBJECTID]}" FontSize="44" />                             <TextBlock  Text="XMax" FontSize="44" />  <!These two dont work!>                             <TextBlock  Text="{Binding Extent[XMax]}" FontSize="44" />                             <TextBlock  Text="{Binding Geography[Extent]}" FontSize="44" />
My overall goal is to have a listbox with icons of each point that are images that have image.sources of a bunch of Exported Map Images.  something like this http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StateCityHighway_USA/MapSe... But obviously different for each one and each one being an image of that point. I just think data binding would be the best way to do this.
DominiqueBroux
Esri Frequent Contributor
To get the geometry extent as text in your list box, you can use :
<TextBlock Text="{Binding Geometry.Extent}" FontSize="44" />
That being said I am not sure to understand what you need to do, so not sure that helps.
DominiqueBroux
MattMiley
Thanks! I can take it from there!
