How to assign identify output to an info window
1251
05-09-2013 12:07 PM
DonFreeman
I have an infowindow defined with a datatemplate. I want to perform an identify task and display the result in the infowindow. My code works to popup the infowindow but it comes up empty. How do I make the assignment to get the data into the infowindow? Also, in the definition of the identify task, is there a way to specify the single layer we want the results to come from?
Here is my current code.
private void IdentifyTask_ExecuteCompleted(object sender, IdentifyEventArgs args)
   if (args.IdentifyResults != null && args.IdentifyResults.Count > 0)
   // MessageBox.Show(args.IdentifyResults.Count.ToString());
    MyInfoWindow.Anchor = clickPoint;
    MyInfoWindow.IsOpen = true;
    MyInfoWindow.Content = args.IdentifyResults;
   else
    MyInfoWindow.IsOpen = false;
GirishYadav
args.IdentifyResults is a collection of IdentifyResult. It would be better if you iterate through this collection and  pass IdentifyResult.Feature.Attributes to infoWindow. You need to adjust infoWindow's data template accordingly.
Girish
