how to access esri from excel
1783
7
02-22-2011 06:23 AM
ThaoNguyen
I created a map using C# and esri wpf.
We have an Excel add-in application that can open my map code.  After my queryTask execute completed method is called, I invoked a method to add graphics to map.  I got the following error when adding graphics to graphic layer: graphicMapLayer.Graphics.Add(graphic);
System.InvalidOperationException: The calling thread cannot access this object because a different thread owns it.
   at System.Windows.Threading.Dispatcher.VerifyAccess()
I found a solution by calling Dispatcher.Invoke
e.g. this.Dispatcher.Invoke( new AddGraphicDelegate(AddGraphic), graphic);
private void AddGraphic(Graphic g)
       graphicMapLayer.Graphics.Add(g);
However, after I got the above problem fixed, I got another thread exception for another arcgis method as following:
   at System.Windows.DependencyObject.GetValue(DependencyProperty dp)
   at ESRI.ArcGIS.Client.Graphic.get_Visibility()
   at ESRI.ArcGIS.Client.GraphicsLayer.RenderGraphics(Double resolution, MapPoint canvasOrigin, Envelope env, Envelope bufferedExtent, IEnumerable`1 gfxs, Boolean isClustering, IRenderer renderer, Boolean interactive)
   at ESRI.ArcGIS.Client.GraphicsLayer.Draw(Envelope extent, Double resolution, MapPoint canvasOrigin, Boolean useTransitions)
   at ESRI.ArcGIS.Client.Map.loadLayerInView(Boolean useTransitions, Envelope drawExtent, Layer layer)
   at ESRI.ArcGIS.Client.Map.loadLayersInView(Boolean useTransitions, Envelope drawExtent)
   at ESRI.ArcGIS.Client.Map.panTo(Geometry geometry, Boolean skipAnimation)
   at ESRI.ArcGIS.Client.Map.zoomTo(Geometry geom, Boolean skipAnimation)
   at ESRI.ArcGIS.Client.Map.set_Extent(Envelope value)
Please help!  I don't know where is the right place to call Invoke() in this case that handles all arcgis calls.
Thanks!
ThaoNguyen
Thanks!
Please help me as soon as possible because it is urgent for us :(.  The map cannot be displayed and we cannot test it.  Escalate the problem if you don't know an answer for this.  I really appreciate your concern and understanding.
JenniferNery
I checked with Morten and he explained that you are using the wrong Dispatcher. You will need to get to the root visual, and use its Dispatcher. You can try using Application.Current.MainWindow.Dispatcher.
ThaoNguyen
I tried this and the line Application.Current.MainWindow... threw the same exception.
Let me rewrite my original code structure
private void QueryTask_ExecuteCompleted(object sender, QueryEventArgs args)
    //do some work here that's not related to the question
    Update();
private delegate void NullDelegate();
private void Update()
            try
                if (this.Dispatcher.Thread != System.Threading.Thread.CurrentThread)
                    this.Dispatcher.Invoke(new NullDelegate(Update), null);
                    return;
                //some work here
            }catch (Exception e) { //do something here }
With your suggestion, I did the following:
            try
                if (Application.Current.MainWindow.Dispatcher.Thread != System.Threading.Thread.CurrentThread)
                    Application.Current.MainWindow.Dispatcher.Invoke(new NullDelegate(Update), null);
                    return;
                //some work here
The if line already threw an exception.
JenniferNery
Does it hit this line?
I think the best way to find the parent of your Map control is to use VisualTreeHelper. If you do this in while loop until GetParent() returns null, you will have the Visual root and use its Dispatcher.
Something like this if Map is not a descendant of your Application.Current.MainWindow:
DependencyObject dependencyObject = VisualTreeHelper.GetParent(element);
if (dependencyObject == null)
 return element;
while (VisualTreeHelper.GetParent(dependencyObject) != null)
 dependencyObject = VisualTreeHelper.GetParent(dependencyObject);
rootVisual = dependencyObject as Visual;
You will be able to then use rootVisual.Dispatcher.
ThaoNguyen
 return element;
Tried that, got same exception when doing VisualTreeHelper.GetParent(element).
ThaoNguyen
Do you have any other ideas after all of these solutions failed?  You can tell me the big picture like where I should invoke the map container dispatcher or you can give me an example that worked on excel.
Thanks!
ThaoNguyen
Thanks!
We found that the Graphic instances created by Arcgis after QueryTask was completed in another thread.  Temporarily, we have to create a new Graphic for each Graphic returned and pass in only info that we need.  This resolved the problem.
I don't have to call dispatcher from mainwindow with this solution.
