How select symbol of graphiclayer added in runtime?
3524
01-12-2011 02:14 PM
StefhanCampos
Hi, i added many symbols on graphiclayer in runtime. Now i want draw a rectacle or polygon and get all symbols of graphiclayer in rect/polygon area(something like contains drawobject), how i can do that?
ps:cannot use new api feature "Editor".
JenniferNery
I'm sorry I did not understand the question. Are you trying to use Draw (similar to this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#DrawGraphics) ? And you are trying to set or get the graphic symbol?
StefhanCampos
i create a layer in tuntime and add graphics:
 MyMap.Layers.Add(new GraphicsLayer() { ID = "MyGraphicsLayer"});
GraphicsLayer graphicsLayer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            ESRI.ArcGIS.Client.Graphic graphic = new ESRI.ArcGIS.Client.Graphic()
                Geometry = args.Geometry,
                Symbol = _activeSymbol,
            graphicsLayer.Graphics.Add(graphic);
now i want search this graphics, eg: Draw a retacle, and get all points  in this area. i will use:FindGraphicsInHostCoordinates ??
DanielWalton
Take a look at the Draw sample that Jennifer posted. In the method Draw_Complete(), you have access to a graphic object that represents the shape you just drew. You can use this shape to interrogate the features in any other graphicslayer. Here's a useful bit of code for doing that (taken from the ESRI Contrib project😞
        public static bool IsPointInPolygon( PointCollection points, MapPoint point )
            int i;
            int j = points.Count - 1;
            bool inPoly = false;
            for( i = 0; i < points.Count; i++ )
                if( points[ i ].X < point.X && points[ j ].X >= point.X
                  || points[ j ].X < point.X && points[ i ].X >= point.X )
                    if( points[ i ].Y + ( point.X - points[ i ].X ) / ( points[ j ].X - points[ i ].X ) * ( points[ j ].Y - points[ i ].Y ) < point.Y )
                        inPoly = !inPoly;
                j = i;
            return inPoly;
You can call Graphic.Select() or whatever on any graphics objects that fall inside the shape.
JenniferNery
If you want to select graphics by drawing a rectangle around them, you can use the Editor.Select command. Try the "New Selection" button in this SDK Sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#EditToolsAutoSave. This also works for GraphicsLayer. Note, however that the Symbol you use need to define SelectionStates to be able to distinguish between Selected and Unselected states as in this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SelectGraphics.
And yes, another way is to use FindGraphicsInHostCoordinates http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.GraphicsLa... to return you the graphics contained in the rectangle.
