How does infoWindow work with dynamic map service in Silverlight?
3320
10-13-2011 01:12 PM
XiujuZhou
I have dynamic map service in my web application using ArcGIS API 2 for silverlight 4. I need infoWindow display feature attributes when mouse is over a feature in a layer of the dynamic map service. If anyone can share some idea, solution or kindly code, that would be great help!
JenniferNery
You cannot show InfoWindow on MouseOver but you can perform an Identify on MouseClick and show the result in InfoWindow.
MyInfoWindow.Content = IdentifyResult.Feature.Attributes;
BrianHjort_Nielsen
Is this all you need to add to the "Click" event? or is there more code you need to add?
I have a DynamicMapService, that i need to query with a mouse click event, and have an InfoWindow showing the results, do i need to write a query in the click event, or will the code you posted suffice?
i can´t use the layer(s) as a featurelayer, becouse i need it to have the symbols provided from the map service.
