how do I zoom by scale?
912
07-19-2010 06:03 AM
jonataspovoas
My Application has two pages: The main navigation page and a print childWindow.
During execution time, if the user clicks on the print button, the print childwindow pops up showing the map inserted in a Print Layout.
The problem is that each page has diferent dimensions, and when i pass the map from one another, i make a zoom passing the envelope from the other. With this, the scale of the map changes.
Is there anyway to Zoom using the scale instead of the envelope?
here's how I Zoom the map:
printer.printMap.ZoomTo(this._extentHistory[this._currentExtentIndex]);
_extentHistory is a List of Envelopes that records the map interactions.
_currentExtentIndex a int that records the actual position in the history of interactions.
dotMorten_esri
Esri Notable Contributor
You would have to adjust the extent accordingly to expand/clip it based on the new print size.
