How do I save a graphic selected from one feature layer to another feature layer
1293
03-25-2011 08:46 AM
MuralidharMoka
Hi.
I have two similar  feature layers f and fmh .
f has some features  and fmh is empty.
Now I select a graphic from f  and then want to add that to fmh.
I am doing it like this.
  void f_MouseLeftButtonUp(object sender, ESRI.ArcGIS.Client.GraphicMouseButtonEventArgs e)
            Graphic SelectedGraphic= e.Graphic;
               fmh.Graphics.Add(SelectedGraphic);  //I get an error here
               fmh.Update();   //is this right
I get an error like this
"Specified argument was out of the range of valid values.\r\nParameter name: Cannot add graphic to multiple graphiclayers"
Can any one help me with this.
DominiqueBroux
Esri Frequent Contributor
One graphic can't be added to 2 graphics layers.
So you have to create a new graphic.
Something like:
var newGraphic = new Graphic { Symbol = oldGraphic.Symbol, Geometry = Geometry.Clone(oldGraphic.Geometry), Attributes = oldGraphic.Attributes };
MuralidharMoka
Hi Dominique
Thank you for the reply.
I trying to write code like this
Graphic g= new Graphic()
                                     Symbol = selectedGraphic.Symbol,
                                     Geometry = selectedGraphic.Geometry, //I did not find clone so is this right
                                    Attributes = selectedGraphic.Attributes //gives an error at compile time
Error: Property or indexer 'Attributes' cannot be assigned to -- it is read only
DominiqueBroux
You right. I forgot that.
You have to add the attribute one by one:
foreach (var kvp in selectedGraphic.Attributes)
        g.Attributes.Add(kvp);
MuralidharMoka
Thanks very much. This really helped me.
Great support.
Muralidhar Moka
