How Command esri:Map mouseclick?
2943
07-29-2010 12:55 PM
StefhanCampos
Hi, i am using MVVM  approach,i need "command mouseclick" to get current
coordinates, anyone know  ?
JenniferNery
You would usually use MouseLeftButtonDown event to do this, get the screen point and translate them to the actual map coordinates.
System.Windows.Point screenPoint = args.GetPosition(MyMap);
ESRI.ArcGIS.Client.Geometry.MapPoint mapPoint = MyMap.ScreenToMap(screenPoint);
You can refer to this blog for Binding EventArgs to a Command http://silverlight-essentials.com/blog/
Jennifer
DarinaTchountcheva
Try this link:
http://blogs.infosupport.com/blogs/alexb/archive/2010/04/02/silverlight-4-using-the-visualstatemanag...
Read the whole article, the title doesn't say anything about commands, but look at the code.
I have used it, and it worked for me.
Good Luck!
jonataspovoas
You can do this
public MainPage
  InitializeComponent();
  MyMap.MouseLeftButtonDown +=new MouseButtonEventHandler(MapaImpressao_MouseLeftButtonDown);
/* This triggers when the the button is PRESSED! if you want it to Trigger when the user stops
 * holding the button, change Down to Up.
 * Also, if you want that if works if the Right button instead of the left, change Left to Right.
private void MyMap_MouseLeftButtonDown(object sender, MouseButtonEventArgs e)
            //This shows the coordinates relative to the Root of the application
            MessageBox.Show(string.Format("X: {0}, Y: {1}", e.GetPosition(LayoutRoot).X, e.GetPosition(LayoutRoot).Y));
            //This shows the coordinates relative to the Map of the application
            MessageBox.Show(string.Format("X: {0}, Y: {1}", e.GetPosition(MyMap).X, e.GetPosition(MyMap).Y));
            //changing "MyMap" to any other object on the screen (like an Grid, or Border) will change the Reference of the coordinates
            //This 2 lines bellow will center the point you clicked on the map.
            MapPoint coordinate = new MapPoint(e.GetPosition(MyMap).X, e.GetPosition(MyMap).Y);
            MyMap.PanTo(coordinate);
I hope this is useful xD
