Highlight graphics from results window mouse over
3108
10-15-2010 10:38 AM
ChrisBradberry
Hey,
I have the results from a querytask in a drop down window.  The locations are displayed with a graphic.  I was wondering how to highlight or change the graphic when you mouse over the results in the dropdown window. I would like the user to know which graphic goes with the result.
Thanks, Chris
dotMorten_esri
Esri Notable Contributor
I usually define a selection state on the graphic, and when I perform a roll-over, set the graphic to selected, and unselected when I roll out again.
Here's an example of this in action:
http://resources.esri.com/arcgisserver/apis/silverlight/index.cfm?fa=codeGalleryDetails&scriptID=161...
(note that this is a very old sample and was written with v1.0beta, so a couple things might have changed, but the idea is the same)
ChrisBradberry
Thanks Morten,
That is exactly what I want.
Chris
ChrisBradberry
Here is the code that I used to get it to work.
Chris
 private void TextBlock_MouseEnter(object sender, MouseEventArgs e)
            QueryResultData HiLight = (QueryResultData)(sender as FrameworkElement).DataContext;
            Graphic g = getGraphic(HiLight);
            g.Symbol = SearchSelectedSymbol;
            if (g != null)
                g.Select();
                g.SetZIndex(1);
        private void TextBlock_MouseLeave(object sender, MouseEventArgs e)
            g.Symbol = SearchPictureSymbol;
            if (g != null)
                g.Select();
                g.SetZIndex(0);
        private Graphic getGraphic(QueryResultData HiLight)
            GraphicsLayer layer = MyMap.Layers["MyGraphicsLayer"] as GraphicsLayer;
            if (HiLight != null && layer != null)
                foreach (Graphic g in layer.Graphics)
                    if (g.Geometry == HiLight.SHAPE)
                        return g;
            return null;
dotMorten_esri
A much more efficient way would be to use the visual states instead of replacing the symbol as suggested. It will perform better and not "flicker".
