Help in filter Where: FindParameters Class & LayerDefinitions
2639
10-05-2010 01:25 PM
YgorThomaz
Hello guys,
I am creating a FindTask and must use the class and property FindParameters LayerDefinitions (get; set;): IEnumerable <LayerDefinition>. Can anyone send an example of "Where (filter)" using LayerDefinitions?
Part of code bellow :
        private void ExecuteButton_Click(object sender, RoutedEventArgs e)
            GraphicsLayer graphicsLayer = Mapa.Layers["MyGraphicsLayer"] as GraphicsLayer;
            graphicsLayer.ClearGraphics();
            FindTask findTask = new FindTask("http://192.168.5.../MapServer");
            findParameters.LayerDefinitions = ???;
            findParameters.SearchText = FindText.Text;
            findTask.ExecuteAsync(findParameters);
Thank´s!
YgorThomaz
Hello,
I worked in my code last night. But, i have a new problem, please take a look in my code:
            FindTask findTask = new FindTask("http://192.168.5.104/ArcGIS/rest/services/MDSalvador_Pesquisas/MapServer");
            findTask.Failed += FindTask_Failed;
            FindParameters findParameters = new FindParameters();
            // Layer ids to search
            findParameters.LayerIds.AddRange(new int[] { 1, 2 });
            // Fields in layers to search
            findParameters.SearchFields.AddRange(new string[] { "TOPONIM", "NM_BAIRROS" });
            string termoProcuradoSemAcentos = RemoveAcentos.removeAcentos(FindText.Text);
            ObservableCollection<LayerDefinition> layerDefs = new ObservableCollection<LayerDefinition>();
            layerDefs.Add(new LayerDefinition()
                LayerID = 1,
                Definition = "UPPER(TOPONIM_CI) like UPPER('%" + termoProcuradoSemAcentos + "%')"
                LayerID = 2,
                Definition = "UPPER(NM_BAIRROS_CI) like UPPER('%" + termoProcuradoSemAcentos + "%')"
            findParameters.LayerDefinitions = layerDefs;
            // Bind data grid to find results.  Bind to the LastResult property which returns a list
            // of FindResult instances.  When LastResult is updated, the ItemsSource property on the
            // will update.
            Binding resultFeaturesBinding = new Binding("LastResult");
            resultFeaturesBinding.Source = findTask;
            FindDetailsDataGrid.SetBinding(DataGrid.ItemsSourceProperty, resultFeaturesBinding);
            //findParameters.SearchText = FindText.Text;
My problem is that the property "findParameters.SearchText = FindText.Text;" it's necessary. However, my conditions in "findParameters.LayerDefinitions = layerDefs;" are not considered.
JenniferNery
You can try the following code. I tweaked just the highlighted code from this SDK sample: http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#Find
   FindTask findTask = new FindTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer");
   findTask.ExecuteCompleted += (a, b) =>
     Dispatcher.BeginInvoke((Action)delegate
      MessageBox.Show(string.Format("Result.Count: {0}", b.FindResults.Count));
   findParameters.LayerIds.AddRange(new int[] { 0, 1, 2 });
   findParameters.SearchFields.AddRange(new string[] { "CITY_NAME", "NAME", "SYSTEM", "STATE_ABBR", "STATE_NAME" });
   findParameters.LayerDefinitions = new LayerDefinition[]
    new LayerDefinition() { LayerID = 0, Definition = "STATE='California" },
    new LayerDefinition() { LayerID = 2, Definition = "STATE='California" }
   findParameters.SpatialReference =new SpatialReference(4326);
   findParameters.SearchText = "River";
