heatmap example
687
12-12-2011 04:51 AM
johnbrosowsky
where is heatmap example code for:
http://www.arcgis.com/home/item.html?id=7276e0a3d26b4243b3935e3082847150
... I know heatmaplayer is now avaialble directly in ArcGIS API for Silverlight.  However, the original code example (I think the one above) from before heatmaplayer was avaialble directly in ArcGIS API for silverlight, was quite useful for demonstrating a particular technique I need to see again.
Thanks!
DominiqueBroux
Esri Frequent Contributor
The heat map code source is provided on codeplex : http://esrisilverlight.codeplex.com/
The actual version is very close of the original version.
