Heat map default gradient
3175
05-28-2012 05:27 AM
JobyGeorge
Hi ,
Can anyone give me the default gradient of the heat map?
thanks & regards,
Joby
DominiqueBroux
Esri Frequent Contributor
The Heat map layer code is published here : http://esrisilverlight.codeplex.com/
The default gradient is :
GradientStopCollection stops = new GradientStopCollection(); stops.Add(new GradientStop() { Color = Colors.Transparent, Offset = 0 }); stops.Add(new GradientStop() { Color = Colors.Blue, Offset = .5 }); stops.Add(new GradientStop() { Color = Colors.Red, Offset = .75 }); stops.Add(new GradientStop() { Color = Colors.Yellow, Offset = .8 }); stops.Add(new GradientStop() { Color = Colors.White, Offset = 1 }); Gradient = stops;
DominiqueBroux
JobyGeorge
Gradient = stops;
This worked for me, thanks dbroux
