has anyone been able to serialize IdentifyResults and/or it's collection
1161
02-17-2011 04:44 AM
SangamLama
I'm carrying out an IdentifyTask on the provider layer of my application. It returns a List<IdentifyResult> which needs to be passed to the SL side through my WCF service. I was looking this example,
http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2010/03/11/Sending-geometry-between-Silverlig...
and MapPoint gets serialized just as easily. But IdentifyResult doesn't.
Help?
JenniferNery
What error are you getting? Are you serializing just the geometry? I'm guessing the trouble is serializing the entire Graphic, which includes Symbol.
This related thread might help: http://forums.arcgis.com/threads/8774-save-layer-to-xml-file
SangamLama
The error's a bit difficult to understand to be honest. I wont copy/paste the entire strack trace here, but here's how it goes
An ExceptionDetail, likely created by IncludeExceptionDetailInFaults=true, whose value is:
System.InvalidOperationException: An exception was thrown in a call to a WSDL export extension: System.ServiceModel.Description.DataContractSerializerOperationBehavior
contract: Silverlight.ESRIMapping:ESRIMappingService ----> System.Runtime.Serialization.InvalidDataContractException: Type 'System.Windows.Input.TouchDevice' cannot be serialized. Consider marking it with the DataContractAttribute attribute, and marking all of its members you want serialized with the DataMemberAttribute attribute.  If the type is a collection, consider marking it with the CollectionDataContractAttribute.  See the Microsoft .NET Framework documentation for other supported types.
   at System.Runtime.Serialization.DataContract.DataContractCriticalHelper.ThrowInvalidDataContractException(String message, Type type)
what you said does make sense. Currently, I'm trying to declare a serializable class where I have all the properties as in IdentifyResult, but skip the symbol because I don't need it here...
SangamLama
nvm. Along the way, I had been trying to serialize a map itself. How brave and stupid 😛
