Graphics front-back
3780
04-30-2012 11:52 AM
LuisGarcia2
I have a graphics layer where I add several graphics. Some times the graphics are very close and there are some I would like to bring to the front so the client can have a better view of them. Is there any way to do that programmatically? I did not see anything in the API.
Thanks!
LuisGarcia2
Never mind. I think I got it. What I did was to set the Z-index to 0 in all the graphics I have when I instantiate them to make sure they are all at the lowest level. When I need to show them on top of the others I set the z-index to a high number and they show the way I want. I can re-set them to zero if I want them back at the level they were first.
Thanks for your help!
JenniferNery
You can probably check collision by using Extent.Intersects() and setting Graphic.SetZIndex(index) or stack order of the graphic in the collection.
LuisGarcia2
Jennifer,
thanks for your reply. I tried the z order which I thought was a the fastest procedure and did not get good results. Not sure why. I got the count of graphics that I had at the specific moment in the  layer so it would be the highest number possible and set the z index with that and still they were overlapping. I also tried using this:
Graphics.Move(Graphics.IndexOf(myGraphic), 0);
That does the trick when I do one by one; but if I do several at the same time the graphics disappear from the screen for an instance. That tells me that likely the "move" algorithm is more time consuming (and I think that make sense).
So, any advice with the z-index? Is that the right way to use it? I'd like to use that approach if possible so the graphics don't flicker like that.
Thanks!
LuisGarcia2
