Graphic Layer Selection is not okay.
2517
5
02-13-2012 01:18 PM
SelçukTınaz
Hi Everyone,
    I have some Query and i am collecting Query results graphics, no problem with this. But,
When i try to show the result geometries in graphic layer, my geometry (in graphic layer) and real geometry are not
matching. Graphic Layer's geometry is just a little split. I control my spatial reference objects, it does not look like any problem.
Any Idea about this,
Thanks in Advance.
DominiqueBroux
Esri Frequent Contributor
Seeing your screenshot, it's not a MaxAllowableOffset issue.
I am more thinking about a projection accuracy issue.
Try by setting the spatial reference of your map to the spatial reference of your service (by initializing a map Extent in this SR). Might give a clue.
DominiqueBroux
Might be an effect of the Query.MaxAllowableOffset parameter. Try by decreasing this value.
Else please share a screencopy highlighting the issue, that might give a clue.
SelçukTınaz
Thanks for your answer.
I tried Query.MaxAllowableOffset parameter. But no change happen.
Firstly, can you give me an example value for this parameter and i added an image that shows
my problem.
It makes me crazy.
Thanks again...
DominiqueBroux
SelçukTınaz
   Thank you so much for your answers and interest. I will try my best and then
I will return if i managed it. (I hope i manage).
SelçukTınaz
Hi again me,
About the problem i try everything but no solution. I control map spatial reference (102100). Then i query for graphics with IDs and task outpuspatialReference is also
102100. But it shows wrong. Any help please?
Thanks.
