GPServer Submit job (get) failing
3589
6
01-08-2014 09:21 AM
jonataspovoas
I created a Geoprocess to upload an AutoCAD file (dxf) and return a Polygon contained in it. When I run the service using a post message, it runs and concludes sucessfuly. But when I try to use the service via get or Silverlight (wich also uses get) the service fails for the same file.
Here's the code that calls my service:
private void LoadCADFile(object sender, RoutedEventArgs e)
 var openFileDialog = new OpenFileDialog
  Multiselect = false,
  Filter = "AutoCAD File (*.dxf)|*.dxf",
  FilterIndex = 1
 openFileDialog.ShowDialog();
 if (openFileDialog.File == null) return;
 var fileStream = openFileDialog.File.OpenRead();
 var uploadTask = new UploadTask(@"http://oba:6080/arcgis/rest/services/SAEB/AutoCad/GPServer")
  DisableClientCaching = true
 uploadTask.UploadCompleted += CADFileLoaded;
 uploadTask.UploadAsync(new UploadParameters
  FileName = openFileDialog.File.Name,
  FileStream = fileStream,
private void CADFileLoaded(object sender, UploadEventArgs e)
 var geoprocessor = new Geoprocessor(@"http://myserver/arcgis/rest/services/AutoCad/GPServer/AutoCad")
  DisableClientCaching = true,
  ReturnM = false,
  ReturnZ = false
 geoprocessor.JobCompleted +=
  (s, args) =>
   args.JobInfo.Messages.ForEach(
    message =>
     MessageBox.Show(message.Description, message.MessageType.ToString(), MessageBoxButton.OK));
 geoprocessor.SubmitJobAsync(new List<GPParameter>
  new GPItemID("Parque_de_Pituaçu_2013__wgs84__dxf",
      e.Result.Item.ItemID)
AnthonyGiles
Honored Contributor
Jonatas,
Have you looked at your server logs to see what may be causing the issue? Have you tried the gp service in both asynchronous and synchronous modes?
Regards
Anthony
DominiqueBroux
Esri Frequent Contributor
What is the version of ArcGISServer?
If I remember well, Upload is available only from 10.1 or 10.1 SP1.
To check that, you can browse to http://oba:6080/arcgis/rest/services/SAEB/AutoCad/GPServer and verify that there is an 'Uploads' child resource.
With previous version you have to use a GPDataFile.
jonataspovoas
Jonatas,
Regards
Anthony
Yes i have, these are the messages that my server is returning:
Job Messages:
esriJobMessageTypeInformative: Submitted.
esriJobMessageTypeInformative: Executing...
esriJobMessageTypeError: ERROR 000735: Parque de Pituaçu 2013 (wgs84).dxf: Value is required
esriJobMessageTypeError: ERROR 000735: Parque de Pituaçu 2013 (wgs84).dxf: Value is required The value is empty. ERROR 000735: Input Data Element: Value is required
esriJobMessageTypeError: Failed.
I tried to run my gp service as asynchronous and synchronous, but in both cases i had the same error.
jonataspovoas
The version of my ArcGISServer is 10.1 SP1.
AnthonyGiles
Honored Contributor
It looks like your file is not getting uploaded or not making it in to your process.
Have you tried creating a parameters object and passing that object in the geoprocessorTask.SubmitJobAsync function.
Example shown here:
http://resources.arcgis.com/en/help/silverlight-api/concepts/#/Geoprocessing_task/01660000000n000000...
Regards
Anthony
jonataspovoas
Example shown here:
Regards
Anthony
Yes i have, in my code below i am passing a list of GPParameters where my object parameter is a GPItemID.
