Getting Driving Directions using lat/long instead of physical addresses
4027
6
11-30-2010 10:09 AM
SangamLama
Hi all,
If I am to pass lat/long instead of physcial addresses for both starting and ending point of a route, how would I pass that?
The live sample shows how to get directions using physical addresses.
Could anyone provide a brief example?
Thanks
JenniferNery
The Geocode service you are using should be able to accept lat/lon fields to identify a location.
In this sample, http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#RoutingDirections, notice that Locator calls AddressToLocationAsync. Instead, you need to call LocationToAddressAsync as in this other sample, http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#LocationToAddress.
SangamLama
Hi there,
Here's how I implemented Driving Directions. It doesn't work because I haven't called LocationsToAddress function. I wanted to first understand why I need to use it to begin with. Because it seemed to me that as long as the Mappoints for starting and ending addresses were passed in Stops, I was good to go?
Could someone take a peak at what I've done and explain what's missing where? Both the stops have lat/long instead of physical address.
public RouteResult GetDirections(double latitude, double longitude)
            List<Graphic> _stops = new List<Graphic>();
            MapPoint point1 = new MapPoint();
            point1.X = latitude;
            point1.Y = longitude;
            Graphic stop1 = new Graphic() { Geometry = point1 };
            List<AddressCandidate> startingAdd = GeocodeAddress("380 New York St, Redlands, CA, 92373");
            AddressCandidate start = startingAdd[0];
            MapPoint point2 = new MapPoint();
            point2.X = start.Location.X;
            point2.Y = start.Location.Y;
            Graphic stop2 = new Graphic() { Geometry = point2 };
            _stops.Add(stop1);
            _stops.Add(stop2);
             _routeTask = new RouteTask("http://tasks.arcgisonline.com/ArcGIS/rest/services/NetworkAnalysis/ESRI_Route_NA/NAServer/Route");
            _routeTask.SolveCompleted += _routeTask_SolveCompleted;
            _routeTask.Failed += _routeTask_Failed;
            _routeTask.SolveAsync(new RouteParameters()
                ReturnRoutes = false,
                ReturnDirections = true,
                DirectionsLengthUnits = esriUnits.esriMiles,
                Stops = _stops,
                UseTimeWindows = false
            handle.WaitOne();
            return _routeResult;
void _routeTask_SolveCompleted(object sender, RouteEventArgs e)
            _routeResult = e.RouteResults[0];
            handle.Set();
        void _routeTask_Failed(object sender, TaskFailedEventArgs e)
            _routeResult = null;
            handle.Set();
Thanks!!
JenniferNery
Ah okay I see what you're doing now.
In this case, you do not need LocationToAddressAsync nor AddressToLocationAsync.
Using this sample http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#RoutingDirections, I commented out code for initializing locator and subscribing to its events. Instead, I subscribed to MouseClick.
 if (_stops.Count < 2)
  _stops.Add(new Graphic(){Geometry = e.MapPoint});
 if(_stops.Count == 2)
  _routeTask.SolveAsync(_routeParams);
Since you already have the lat/lon values, you do not need to get MapPoints from an event such as MouseClick, you can simply do:
_stops.Add(new Graphic(){Geometry = new MapPoint(lat, lon}); // for both start and end location.
That should be all you need to do.
SangamLama
Hi Jennifer,
thanks for the response. That did clear out the confusion. I found the bug that was causing the function to not work properly.
Let me confirm this with you -- for class MapPoint, X property means latitude, and Y property means longitude? or is it the other way around?
DominiqueBroux
Esri Frequent Contributor
It's the other way : X means longitude and Y means latitude.
SangamLama
thank you!
