Get SubLayerID upon clicking on layer's name
1410
06-24-2012 09:55 PM
MiriEshel
I have a legend like this:
       <Style TargetType="esri:Legend">
            <Setter Property="LayerItemsMode" Value="Tree" />
            <Setter Property="ShowOnlyVisibleLayers" Value="False" />
            <Setter Property="LayerIDs" Value="USAID_Layers" />
            <!-- Legend.LayerTemplate with checkbox for sublayer visibility-->
            <Setter Property="LayerTemplate">
                <Setter.Value>
                    <DataTemplate>
                        <StackPanel Orientation="Horizontal">
                                   <Grid VerticalAlignment="Center">
                                    <CheckBox IsChecked="{Binding IsEnabled, Mode=TwoWay}" />
                                    <CheckBox IsChecked="{Binding IsEnabled}" IsEnabled="{Binding IsVisible}" IsHitTestVisible="False" />
                                </Grid>
                                 <TextBlock Text="{Binding Label}" VerticalAlignment="Center" Margin="2,0,0,0" MouseLeftButtonDown="TextBlock_MouseLeftButtonDown" />
                            </StackPanel>
                        </StackPanel>
                    </DataTemplate>
                </Setter.Value>
            </Setter>
        </Style>
       private void TextBlock_MouseLeftButtonDown(object sender, MouseButtonEventArgs e)
            TextBlock textSender = (TextBlock)sender;
            string layerName = textSender.Text;
Upon cliking on the Textblock, I can get the layer name. I also need the SubLayerID in the same click. How can I grab that?
Thanks a lot,
Miri
JoeHershman
One way would be to bind Tag to the SubLayerID
<TextBlock Text="{Binding Label}" VerticalAlignment="Center" Margin="2,0,0,0" MouseLeftButtonDown="TextBlock_MouseLeftButtonDown" Tag="{Binding SubLayerID}"/>
-Joe
MiriEshel
Ho Joe,
Thanks. It works. Simple and elegant.
Miri
DominiqueBroux
Esri Frequent Contributor
Right.
Or get the layerId directly by code without any binding:
  var layerId = (textSender.DataContext as LayerItemViewModel).SubLayerId;
MiriEshel
Dominique,
Thanks to you too. What is the best out of these two options?
Miri
