Get coordinate count only
1455
04-17-2011 04:11 PM
BradBarnell
I there a way to get only the coordinate count or size of a feature with the one of the ESRI tasks?  I have some very large polygons that hang-up my application when a user tries to download and highlight the geometry.
JenniferNery
As far as I know there is no query that can give you this. When you perform a query task with ReturnGeometry=True, you get the shape of the geometry. You may perform Linq query on this result. For example:
var largest = e.FeatureSet.Features.Max(g => g.Geometry.GetArea());
var graphic = e.FeatureSet.Features.FirstOrDefault(g => g.Geometry.GetArea() == largest);
However, this is not very efficient and the result may not be correct. A diagonal polyline's extent is not necessarily its true area. Also the number of vertices does not always guarantee that it will be the largest polygon.
public static class GeometryExtension
 public static double GetArea(this Geometry geom)
  if (geom == null || geom.Extent == null) return 0;
  return geom.Extent.Height * geom.Extent.Width;
 public static int GetVerticesCount(this Geometry geom)
  if (geom is Polygon)
   Polygon polygon = geom as Polygon;
   if (polygon.Rings == null) return 0;
   int count = 0;
   foreach (var pc in polygon.Rings)
    count += pc.Count;
   return count;
  return 0;
DominiqueBroux
Esri Frequent Contributor
From ArcGIS server 10.0 you can also use the maxAllowableOffset option which can be used for generalizing geometries returned by a query, an identify or a find task.
AnastasiaAourik
On a slight tangent,  I do not see Return Count Only available via the Tasks.Query Class.
I have version 2.2.0.629
I see only ReturnIdsOnly and ReturnGeometry, but I cannot set ReturnCountOnly via the ArcGIS api for silverlight.
What gives???
DominiqueBroux
The method is called ExecuteCountAsync.
It is available from SLAPI 2.1 but needs ArcGIS Server 10.0 SP1 to work.
