From silverlight to ASP
6281
10
06-29-2015 06:18 AM
AnatoliiTerentiev
Dear Gurus!
I want to see what I can do with  arcgis when working  without Silverlight.
For example - how I can reproduce next silverlight code
            <esri:Map x:Name="myMap" Background="White" WrapAround="true"
                  Extent="3200000,8500000,4250000,10130000" MouseClick="Map_MouseClick" >
                  <esri:OpenStreetMapLayer ID="OSMLayer" Style="Mapnik" />
                <esri:ArcGISDynamicMapServiceLayer ID="MyMap"
                            Url="http://server:6080/ArcGIS/rest/services/karelia/MapServer" />
            </esri:Map>
in ASP without using silverlight?
ChrisSergent
I have an app I created in .NET using the JavaScript API. Here is some sample code of how I control JavaScript related items using .NET: SOA-Final/default.aspx.vb at master · csergent45/SOA-Final · GitHub
ChrisSergent
AnatoliiTerentiev
If I understand correctly, then something like this
ArcGIS API for JavaScript
AnatoliiTerentiev
Thank you, Chris, I did not notice your reply in time!
ChrisSergent
No problem. If you are interested, I created a group for .NET developers here: .NET and the Esri JavaScript API
I develop in both just the JavaScript API as well as .NET integration with the JavaScript API.
AnatoliiTerentiev
Thank you, certainly join!
AnatoliiTerentiev
Where I can  download Arcgis API for Javascript?  In this   SDK Downloads | ArcGIS for Developers​ I did not see download link only for JavaScript
AnatoliiTerentiev
ChrisSergent
I see you have the information on the other group.
AnatoliiTerentiev
In any case - thanks you very much, Chris!!!
