FlareClusterer only work for WGS84(4326) ?
1250
01-25-2013 06:01 PM
YaohuiLi
hi
I used FlareClusterer to cluster graphics in GraphicsLayer in 4326, it work fine.
recently, I use GaphicsLayer to show something in other spatial reference, not 4326,
and i found that if i set the FlareClusterer to Clusterer of GraphicsLayer, everything disappeared,
and all the Geometry of Graphics in GraphicsLayer been set to null.
I have a CustomGraphicsClusterer class inherit from GraphicsClusterer,
and i found that graphics parameter in ClusterGraphicsAsync always empty.
Someone can tell me what happened? How to fix it?
DominiqueBroux
Esri Frequent Contributor
Seems to be a bug in version 2.4. It's working well with 2.2, 2.3, 3.0, 3.1 versions but not with 2.4.
In 2.4, the workaround is to set the SpatialReference of the map points and of the map extent. With these initializations it's working well.
DominiqueBroux
YaohuiLi
yes. it's working well.
thanks so much.
