Flare Cluster w Gradient: colour chosen has nothing to do with # points in cluster
1641
05-11-2011 08:28 AM
MichaelBlom
Hi there,
If you look at the various clusters in my attached image, and consider their sizes/numbers, the colour along the gradient that is being attributed does not match up.  It seems that the colour chosen has nothing to do with the number of points in the cluster.  Am I missing something?
<esri:FeatureLayer.Clusterer>
                    <esri:FlareClusterer Gradient="{StaticResource GradientBrush}" FlareBackground="#f5cce6" FlareForeground="#3c3c3c" MaximumFlareCount="15" />
</esri:FeatureLayer.Clusterer>
<LinearGradientBrush x:Key="GradientBrush" MappingMode="RelativeToBoundingBox" >
        <GradientStop Color="#990011FF" Offset="0"/>
        <GradientStop Color="#990055FF" Offset="0.25"/>
        <GradientStop Color="#990099FF" Offset="0.5"/>
        <GradientStop Color="#9900CCFF" Offset="0.75"/>
        <GradientStop Color="#9900FFFF" Offset="1"/>
    </LinearGradientBrush>
DominiqueBroux
Esri Frequent Contributor
I agree, it looks like the node  with a count of 266 which should be symbolized with a light blue instead of a dark blue (and more generally the node with the maximum value).
Thanks for reporting this issue. You will try to fix it as soon as possible.
MichaelBlom
Thanks Dominique,
Is there a  way that I can keep track of this bug fix?
Will I need to wait for a new version of the API?
Mike
DominiqueBroux
I will let you know ASAP whether this bug can be fixed in the 2.2 final or not.
We are doing our best but, for now, I am not able to say anything.
Thanks
MichaelBlom
Thanks for you attention to this issue Dominique.
DominiqueBroux
Good news : the fix will be in 2.2 final.:)
