First attempt with MapIt WPF
871
05-17-2010 07:58 PM
xariaD
Installed MapIt 1.1.
Tried to run the Spatial Data Service and get error
Line 65:     <!-- Insert Identity here-->
Line 66:
Line 67:     <identity configProtectionProvider="RsaProtectedConfigurationProvider">
Line 68:       <EncryptedData Type="http://www.w3.org/2001/04/xmlenc#Element"
Line 69:         xmlns="http://www.w3.org/2001/04/xmlenc#">
JamesGoodrich
Hi Xaria.
Could you be more specific about what problem you are experiencing? From the snippet you included it does look like there is an extraneous space on line 67 that should be removed (i.e. "RsaProtectedConfiguratio nProvider" should actually be "RsaProtectedConfigurationProvider"). If you manuallly edit the file to fix this, does the Spatial Data Service then work as expected?
-James
xariaD
The problem was with the credentials.
Resolved now.
Thanks for your help.
