Layer Priorities
971
05-18-2010 09:32 AM
centuitcentuit
Currently I have 2 layers, ElementLayer and GraphicsLayer on the Map
I need to have the GraphicsLayer to be the highest prority, just like ZOrder in windows.
So when I have a Cluster, it should be on top of all the other layers.
Can you provide a sample code on how to do this ?
DominiqueBroux
Esri Frequent Contributor
You have to deal with the order of the layers in the LayerCollection Map.Layers.
I have no code to provide, but as a LayerCollection is also implementing ICollection and IList, it should be easy to change the order.
centuitcentuit
Thanks, it worked.
AvronPolakow
What code did you use with the Icollection or IList?
