Finding Multiple Features with different Searchtexts with FindTask
2536
02-14-2011 11:46 PM
UlfGrimhardt
Hi
I have got a Silverlight App that displays hundrets of different Point-Features in my map.
The Attributes of the Points just consist of Name and Coordinates.
Because of the fact that with ArcGIS Server 9 i cant access "normal" tables that are part of my MXD (Am i right that this is featured in ArcGIS Server 10?), i created a SQL Server Database with different tabels. In This table i have a lot of Attributes for the different Points in my Point-Feature. So for each Point there are n-Entrys in the SQL Table.
My Problem is now, that i need to highlight the Features in my map that have specific attribute values in the SQL Server Table. So in the SQL Server table there are for example Height-Attributes. Now i would like to highlight every point with a Hight greater then 20meters.
I have no Idea how i can realise this effective. The only way i thought about is a Find-Task in my Silverlight App. So first i filter the Data in the SQL Table for every entry greater 20meters. Then i extract the Point-Name of those Entrys.
After that i can do a Find-Task for every Entry. Problem is, that i only can enter one specific SearchText for the Find-Task. So i have to execute the Find-Task for EVERY (maybe 200) Point specifically, but that takes to much time.
Any Ideas? Hope you understand the whole Problem,...i reallly need help!
JenniferNery
You can use FeatureLayer with filtering (update Where clause) as in this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureLayerFiltering. You can also use ClassBreaksRenderer as in this sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureLayerRendering. You can write your own renderer too, you just need to implement IRenderer, specifically GetSymbol() method. http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.IRenderer....
More on Symbols and Renderers:
http://help.arcgis.com/en/webapi/silverlight/help/index.html#/Working_with_Symbols_and_Renderers/016...
And yes you are correct, support for Table is new in ArcGIS Server 10 as described here: http://help.arcgis.com/en/arcgisserver/10.0/apis/rest/layer.html
