finding elements within controltemplate
2250
6
02-11-2011 08:59 AM
YinShi
Hi, following the selections example in the help, I have the following xmal. How do I tab into the stoke property of the Ellipse control and the To property of ColorAnimation? I would like to change those properties in code behind. I've tried graphic.Symbol.ControlTemplate.SetValue (Ellipse.StrokeProperty, new SolidColorBrush(Colors.Red)); and graphic.Symbol.ControlTemplate.GetValue(Ellipse.StrokeProperty);. In either case, I got an exception.
yin
<Grid.Resources>
            <esriSymbols:MarkerSymbol x:Key="SelectMarkerSymbol" >
                <esriSymbols:MarkerSymbol.ControlTemplate>
                    <ControlTemplate>
                        <Ellipse x:Name="Element" Width="15" Height="15" StrokeThickness="10"
         Stroke="Green">
                            <VisualStateManager.VisualStateGroups>
                                <VisualStateGroup x:Name="SelectionStates">
                                    <VisualState x:Name="Unselected" />
                                    <VisualState x:Name="Selected">
                                        <Storyboard>
                                            <ColorAnimation Storyboard.TargetName="Element"
            Storyboard.TargetProperty="(Ellipse.Stroke).(SolidColorBrush.Color)"
            To="Cyan" Duration="00:00:0.25"/>
                                        </Storyboard>
                                    </VisualState>
                                </VisualStateGroup>
                            </VisualStateManager.VisualStateGroups>
                        </Ellipse>
                    </ControlTemplate>
                </esriSymbols:MarkerSymbol.ControlTemplate>
            </esriSymbols:MarkerSymbol>
        </Grid.Resources
JenniferNery
I think you can do make the Storyboard a Resource and change ColorAnimation in code but I don't know if that is a good idea.
I have not tried this but I think syntax is correct.
<Storyboard x:Key="Animation">
<ColorAnimation Storyboard.TargetName="Element" Storyboard.TargetProperty="(Ellipse.Fill).(SolidColorBrush.Color)"
To="Yellow" Duration="00:00:0.25"/>
</Storyboard>
<!--same code as before for SelectMarkerSymbol except for Selected state-->
<VisualState x:Name="Selected" Storyboard="{StaticResource Animation}">
In code-behind:
 Storyboard sb = this.LayoutRoot.Resources["Animation"] as Storyboard;
 ColorAnimation colorAnimation = sb.Children[0] as ColorAnimation;
 colorAnimation.To = Colors.Red;
Why don't you just create a different Symbol if Selected state requires a different ColorAnimation?
YinShi
Hi Jennifer,
Maybe I didn't explain myself clearly. I am looking for ways to enumerate all the controls within a control template in code behind. For example:
    <Grid x:Name="LayoutRoot">
        <Grid.Resources>
            <esriSymbols:TextSymbol x:Key="textSymbol" >
                <esriSymbols:TextSymbol.ControlTemplate>
                    <ControlTemplate>
                        <TextBox Text="{Binding Path=Text}" BorderThickness="0"/>
                    </ControlTemplate>
                </esriSymbols:TextSymbol.ControlTemplate>
            </esriSymbols:TextSymbol>
        </Grid.Resources>
I would like to find the textbox in code behind. Is there any way of enumerating the content of the control template?
JenniferNery
You may be able to use VisualTreeHelper with your ControlTemplate as described in this silverlight forum: http://forums.silverlight.net/forums/p/115213/262980.aspx
YinShi
I tried VisualTreeHelper but it does not take a resource as a parameter. VisualTreeHelper works if the controltemplate is applied to a control but not to a textsymbol. Textsymbol has a controltemplate property. Is there any way I can query again textsymbol.controltemplate to get the active textbox at the run time? I want to interrogate the active textbox at the run time in order to set the text property of textsymbol.
yin
RyanWoodham
I'm also struggling with this.
For me my xaml code is:
 <Application.Resources>
  <ControlTemplate x:Key="MediaFrameTemplate">
   <Grid x:Name="MediaElementContainer">
    <MediaElement x:Name="AppMediaElement" Volume="1.0" Visibility="Collapsed" AutoPlay="True" Source="/02 Beautiful.wma"/>
    <Grid x:Name="ClientArea">
     <ContentPresenter />
    </Grid>
   </Grid>
  </ControlTemplate>
 </Application.Resources>
In the code behind, I'm attempting to find the "AppMediaElement".
ControlTemplate template = (ControlTemplate) Application.Current.Resources["MediaFrameTemplate"] ;
Did you ever solve your problem Yin Shi? Perhaps I can apply the solution to mine.
Best,
Ryan
dotMorten_esri
Esri Notable Contributor
You cannot access or modify properties within a ControlTemplate.
You would have to create a new ControlTemplate instance if you want to change it  (use XamlReader.Load(xamlString) for this).
