FeatureLayerSelection - adding display selected features attributes panel
934
09-27-2010 10:22 AM
BrianPangtay
I like the sample below for selecting features. I altered the sample so that I can choose between the different SelectionModes.
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#FeatureLayerSelection
However, how do I display the attributes of the selected features like in the Spatial Query sample?
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#SpatialQuery
The first sample doesn't trigger a QueryCompleted event and the second sample uses the event.
Thanks for your help.
JenniferNery
In the SpatialQuery example, the query task is created and executed after MyDrawSurface_DrawComplete. If you would like to do the same in the LayerSelection example, you will need to tap into the Editor's EditCompleted event. You also may want to use FeatureDataGrid using featureLayer.SelectedGraphics as its FilterSource.
 public MainPage()
   InitializeComponent();
   Editor editor = this.LayoutRoot.Resources["MyEditor"] as Editor;
   if (editor!=null)
    editor.EditCompleted += new EventHandler<Editor.EditEventArgs>(editor_EditCompleted);
  void editor_EditCompleted(object sender, Editor.EditEventArgs e)
   if (e.Action == Editor.EditAction.Select)
    foreach (var edit in e.Edits)
     if (edit.Layer is FeatureLayer)
      FeatureLayer featureLayer = edit.Layer as FeatureLayer;
      //TODO: display featureLayer.SelectedGraphics in a grid.
dotMorten_esri
Esri Notable Contributor
Can't you just use the FeatureDataGrid and bind it to the layer?
