FeatureLayer Update method does not work
3652
6
05-02-2011 11:13 AM
BrianGustafson
When I try and run the update method on all feature layers in the map I get an error that the object in null.  when i debug this is not the case and all of the information looks correct. I am I using this method right?
FeatureLayer f = new FeatureLayer();
foreach (Layer _layer in MyMap.Layers)
   if (_layer is FeatureLayer)
       f = _layer as FeatureLayer;
       f.Update();
DominiqueBroux
Esri Frequent Contributor
At first glance, your code looks correct.
We will need more infos about the stack trace and the error message when it happens.
BrianGustafson
Here is the stacktrace
   at ESRI.ArcGIS.Client.FeatureLayer.update()
   at ESRI.ArcGIS.Client.FeatureLayer.Update()
   at WorkOrderProcessor.MainPage.CloseWOCompleted(Object sender, CloseWOCompletedEventArgs e)
   at WorkOrderProcessor.WOTask.WOTasksClient.OnCloseWOCompleted(Object state)
I attached an image of the error as well.  Also, when I look at the properties of the object while debugging all of the values are correct (i.e. URL)
DominiqueBroux
Hi Brian,
Thanks for these infos.
Could you also share how the feature layer is created (code, xaml, coming from a web map?) ?
Thanks
BrianGustafson
I included the code to create one of the layers below.  However, I had an idea.  The application I am creating is a tabbed application.  So if a tab with a map on it is not opened is the layer ever initialized?  I am wondering now if the issue is that the layer is never initialized because that tab was never opened.  Could that be the case?
<esri:FeatureLayer ID="MyTreePts" Url="xxxxxxxx" DisableClientCaching="True" Mode="OnDemand"
          Where="COMPLETE_DATE IS NULL" Renderer="{StaticResource MyTreePtRenderer}" MouseLeftButtonDown="FeatureLayer_MouseLeftButtonDown">
          <esri:FeatureLayer.Geometry>
           <esri:Envelope XMin="-113" YMin="27" XMax="-97" YMax="48" >
            <esri:Envelope.SpatialReference>
             <esri:SpatialReference WKID="4326"/>
            </esri:Envelope.SpatialReference>
           </esri:Envelope>
          </esri:FeatureLayer.Geometry>
          <esri:FeatureLayer.OutFields>
           <sys:String>OBJECTID</sys:String>
           <sys:String>COMMENTS</sys:String>
           <sys:String>GLOBALID</sys:String>
          </esri:FeatureLayer.OutFields>
          <esri:FeatureLayer.MapTip>
           <Border CornerRadius="10" BorderBrush="#FF222957" BorderThickness="3" Margin="0,0,15,15">
            <Border.Background>
             <LinearGradientBrush EndPoint="1.038,1.136" StartPoint="0.015,0.188">
              <GradientStop Color="#FFD1DFF2"/>
              <GradientStop Color="#FF0088FF" Offset="0.946"/>
             </LinearGradientBrush>
            </Border.Background>
            <Border.Effect>
             <DropShadowEffect ShadowDepth="10" BlurRadius="14" Direction="300" />
            </Border.Effect>
            <StackPanel Margin="7">
             <TextBlock Text="Tree Point Condition" Foreground="Black" />
             <StackPanel Orientation="Horizontal">
              <TextBlock Text="Comments: " Foreground="Black" />
              <TextBlock Text="{Binding ConverterParameter=COMMENTS, Converter={StaticResource MyDictionaryConverter}, Mode=OneWay}" Foreground="Black" />
             </StackPanel>
            </StackPanel>
           </Border>
          </esri:FeatureLayer.MapTip>
         </esri:FeatureLayer>
DominiqueBroux
That's a good point.
After some research, I found that this may have been fixed in 2.2. Which version are you using?
With 2.1, the workaround might be to test if(layer.IsInitialized) before calling Update.
BrianGustafson
The issue was that the layer was never initialized.  When I only run update on initialized layers it works.  I am using version 2.1 of the API so I don't know if this will work with 2.2.
Thanks.
