FeatureLayer ObjectIDs are ignored
1683
6
07-12-2010 12:40 AM
egismazeika
The documentation states: "If object ids are specified, other query parameters like Where are ignored."
Here's my code:
FeatureLayer edittingLayer;
edittingLayer.ObjectIDs = new int[] { 1 };
edittingLayer.Where = "1=1";
edittingLayer.Update();
All features are returned instead of single one.
DominiqueBroux
Esri Frequent Contributor
ObjectIDs are working from version 10 of ArcGIS server.
Aren't  you using a 9.3 map service?
egismazeika
That was tested on ArcGIS Server 10 beta and final
DominiqueBroux
I just tested with the edit tools sample : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#EditToolsExplicitSave
Adding the code below on a test button gives me a correct result (only one object is visible).
FeatureLayer featureLayer = MyMap.Layers["ThreatAreas"] as FeatureLayer;
featureLayer.ObjectIDs = new int[] { 8649 };
featureLayer.Where = "1=1";
featureLayer.Update();
What could be the difference with your case?
egismazeika
Thank you, Dominique. The sample works fine, but not my services.
I've tried on:
1. SQL Server 2008 (ArcSDE 9.3.1)
2. SQL Server 2008 Express DB created with ArcGIS 10.
Could the DBMS be the reason?
JoelMcBeth
I'm using ArcGIS 10 with Microsoft SQL Server 2008. I have never been able to get a FeatureLayer to use the values in ObjectIDs, it ignores them completely and only uses the Where field for queries.
I just wanted to confirm that this wasn't an isolated incident and I would be interested in getting this working.
JenniferNery
Thank you for reporting this. We are aware of this issue and are working to get this bug fixed in future releases of the API.
